Old 03-25-2021, 08:06 PM
TransAm 474's Avatar
TransAm 474 TransAm 474 is offline
Default 2.50" Register Flywheel to 2.75"... Anyone ever had it done?
Good Evening, has anyone ever had a 2.50" register flywheel bored out to the bigger 2.75" size? I need the 2.75" register for the new Eagle crank, and have 3 good 2.50" register flywheel on hand, so I thought maybe one of those could be bored out to the 2.75" by someone, and then I can have it Neutral balanced to go with my stroker build. Anyone ever had this done?
1978 Trans Am
Pump Gas 461 Stroker
Old 03-25-2021, 08:15 PM
tom s tom s is online now
Ben years ago but yes.tom
The Following User Says Thank You to tom s For This Useful Post:
Old 03-25-2021, 09:20 PM
4dblnkldude's Avatar
I did this 25 years ago. My buddy did it for me. I dont even think I was 20 yet.
The Following User Says Thank You to 4dblnkldude For This Useful Post:
Old 03-26-2021, 12:45 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Yes, it's straightforward. I've also machined up a spacer to go the other way.
The Following User Says Thank You to Jack Gifford For This Useful Post:
Old 03-26-2021, 11:16 AM
Thanks guys, I appreciate the responses. I have actually found a great deal on a new(used for mockup only)Ram 1557 Flywheel that we are going to go with I think.
1978 Trans Am
Old 03-26-2021, 04:50 PM
Formula8's Avatar
Formula8 Formula8 is offline
I did. The machine shop machined it too large and as it was a stock flywheel, I didn't trust it rattling around on the end of the crank and ended up scraping it.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
The Following User Says Thank You to Formula8 For This Useful Post:
Old 03-27-2021, 09:05 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
have done them both ways. Open up the flywheel also make a spacer to locate to a small crank.. non-issue when properly retained.
The Following User Says Thank You to 67Fbird For This Useful Post:
Old 03-27-2021, 11:58 AM
Just to follow up on this guys, I did end up going with the Ram 1557 Flywheel, Neutral Balanced, 2.75" Register, accepts 10.5 and 11" clutch, Made in the USA. I feel like I got a great deal on it, as it was Brand New, used for mockup only.
1978 Trans Am
