Old 03-24-2021, 08:17 AM
dhcarguy's Avatar
dhcarguy dhcarguy is offline
Default 57 Chevy ?
Does anyone know what 4 bl carburator came stock on a 57 Chevy Belair. A friend bought one ,and wanted to know. He wants to get rid of the Holly and put back to stock.
Thanks, Dave
The Following User Says Thank You to dhcarguy For This Useful Post:
Old 03-24-2021, 08:31 AM
jamesq's Avatar
jamesq jamesq is offline
If my memory hasn't failed (which is highly possible), Chevy used a Carter WCFB four barrel.
James Q
James Quayhagen
1963 Bonneville Safari - Nocturne Blue, 4-speed
Old 03-24-2021, 09:42 AM
JohnnyAction JohnnyAction is offline
Hello Dave, The 1957 Chevrolet 283 with powerglide transmission came with the Rochester 4GC carburetor. Early models were # 7008737 and later built models were # 7009846. John
Old 03-24-2021, 10:11 AM
Scott Thelander's Avatar
7009846 fairly sure
on my 57 delivery
Scott
Old 03-24-2021, 10:54 AM
Perhaps it may be only the dual quad 245 hp (auto trans) and 270 hp engines used the WCFB carbs.
Old 03-24-2021, 12:38 PM
jamesq's Avatar
I think you may be correct, I have an uncle with a 57 Vette w/dual quads and the WCFBs are on it.
My old Chilton manual shows both used in 57 Chevy applications.
Sorry for the error!
James Q
James Quayhagen
Old 03-25-2021, 10:08 AM
dhcarguy's Avatar
Thanks EV1
Old 03-25-2021, 05:57 PM
nashcar nashcar is offline
Definitely a q-jet don’t know the number. It was my first car, 283 power-pac, 220 hp.
69 Z 302 M21 3.73
http://www.byjanmarie.com/camaro/Z28.html
69 FB 400
http://www.byjanmarie.com/firebird/69.html
69 Camaro 327 4sp. 4.10
http://www.byjanmarie.com/camaro/69camaro.html ( SOLD)
2002 Camaro LE/SLP-(sold)
1967 Nova SS-- 327, M20, 3.73, FRT Disc
Old 03-25-2021, 07:04 PM
nashcar
no q jets till 65'
57 was a 4GC rochester 4 jet if it was a single 4bbl
Old 03-25-2021, 07:18 PM
My mistake, I always thought all Rochester’s were q-jets. Thank you, I’m a little smarter now.
69 Z 302 M21 3.73
69 FB 400
Old 03-26-2021, 08:50 PM
SRR's Avatar
SRR SRR is offline
Default Carb
Heavy suckers too as the base is cast iron.
― Calvin Coolidge
Old 04-02-2021, 03:01 AM
lust4speed's Avatar
Ridiculously heavy carbs. I have a friend that owns a 56 Belair, 57 Belair, and a 57 Cameo and I've rebuilt those carbs plus a spare for each. Doesn't hurt to paint the cast iron bottom or they become a rusty mess in short order.
Mick Batson
1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon.
Old 04-08-2021, 10:18 AM
dhcarguy's Avatar
Thanks again EV1,
Ok , I took the carb apart and rebuilt it for my buddy. The first thing that happened was the power piston fell out as soon as I lifted the air horn up. Second ,the boot on the pump was soft and deformed. other than that ,it was just real dirty inside.
Took his car out for a ride after putting it back on and it runs good now. There is a slight stumble just coming off idle ,but as soon as he gives it more gas ,it runs great. I am thinking ,maybe because I did look at the jets that were in the carb and cleaned them up. The primary jets are ,048's and the secondary jets are .068's . Could that be the problem. I think they are too big,and should be maybe around .060's in the secondary's.
What do you guys think?
Thanks for all the help, Dave
