Old 03-17-2021, 12:17 PM
punkin punkin is offline
Default Carbon Fiber Driveshaft
Hello all,
My 68 firebird project continues to drag out but hopefully it will be worth it in the end.
New motor in hand, 4L80e on the way and a 9" rear in the works. Obviously a lot of changes and a new drive shaft will eventually be required. I'm very interested in a carbon fiber unit. I did do a quick search of the forums and all I found so far were some rather older exchanges so I do apologize if this has been discussed at great length already.
In my search, it appears QA1 has a great deal of confidence in their product being suitable for high-performance applications as well as street use. Also according the info offered by QA1, other than cost, not a lot of drawbacks. Some considerations include clearance and heat. No X or h-pipe planned so other than making sure I can get full suspension travel and draining my savings even further, this looks like a good choice.
Anyone with any real world experience with carbon fiber drive shaft used on the street? My application again is for 68 firebird.
Thanks in advance for taking the time to read this posting. Have a great day.
1968 Firebird
IAIIa 522
340 E-heads
Northwind with XFlow TBI
4L80E
3.50:1 Rear
Old 03-17-2021, 12:24 PM
turbo69bird's Avatar
Man I’d be real worried on the street something would come up and whack that thing leave you stranded . I’ve thought about it too but sounds too fragile
For me with all the warnings
960 HP @ 11 psi, 9.70 at 146.
Old 03-17-2021, 12:29 PM
4zpeed's Avatar
4zpeed 4zpeed is offline
Good point if one is building for the street, consider a loop?
No shaft failures myself so far but always something to consider.
Here is a thread with what might be some relative insight and info.
https://forums.maxperformanceinc.com...d.php?t=848617
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
The Following User Says Thank You to 4zpeed For This Useful Post:
Old 03-17-2021, 12:37 PM
JLMounce JLMounce is offline
You've got a high performance build going on. If it's in your budget, I'd run it.
The street issue typically comes up because the carbon shafts won't bend or dent, they just disintegrate if they have a catastrophic event. Modern sports car and muscle car enthusiasts including the Supra guys, 3000 GT's Mustang, Camaro's etc. all have large contingents of people daily driving cars on the street with carbon fiber driveshafts.
In the end if something happens that is going to destroy that shaft and leave you stranded, the same would have happened to a steel or aluminum shaft. As with all driveshafts, hitting something rigid hard enough is going to irreparably damage it and you're not going far, or anywhere at that point. Case in point there are warnings all over factory steel driveshafts on modern cars stating if it's dropped, it needs replaced.
Additionally, many of the carbon drive shafts on the market, like from ACPT are actually a thin-wall aluminum core, strengthened with use of a composite wrap.
Common road debris that wouldn't otherwise damage your vehicle, is not going to damage a carbon driveshaft. If something fluke happened like a piece of angle iron getting wedged into the shaft were to occur, again, it's taking out the steel/aluminum unit as well.
-Jason
1969 Pontiac Firebird
The Following User Says Thank You to JLMounce For This Useful Post:
Old 03-17-2021, 12:58 PM
Mike Davis's Avatar
I run a PST Carbon Fiber in my 66. It has held up to almost 775HP for about 4 years now. I mostly race the car but do drive it on the street a good bit. I would have no problem running one on a street car. They are slot safer than any steel or aluminum shaft.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
The Following User Says Thank You to Mike Davis For This Useful Post:
Old 03-17-2021, 01:29 PM
Fantastic input all. Thank you.
As for the safety loop(s) I do have one but I do plan for a far more beefy solution that will be integrated with the new drive shaft cross-member. I've also seen some interesting solutions for a second loop as part of the rear housing. Once everything is assembled I'll need to have a long look at suspension travel before committing to this solution.
A number of years back I did have a steel drive shaft attempt to exit the car. Beat the dickens out of the underside. After seeing what is possible, I'm really avoidant to the aluminum solution. I would far rather the drive shaft disintegrate than experience that all over again.
Again, thanks to you all.
1968 Firebird
IAIIa 522
340 E-heads
4L80E
3.50:1 Rear
The Following User Says Thank You to punkin For This Useful Post:
Old 03-20-2021, 03:06 AM
GOAT8U2's Avatar
GOAT8U2 GOAT8U2 is offline
Heat = Kills Carbon Shafts
I was gonna buy one and had PST and other online threads suggest that is not worth the risk. It was made pretty clear that heat is the enemy of these shafts, any exhaust pipe that's nearby puts the shaft at risk.
I had a friend break his with low miles on it, many Mopar guys were having the same issue in their street cars. While I don't technically have one, I was ready to buy it and was suggested by the company to not put it in my street car GTO.
69 GTO Convertible, 4000lbs
462ci, 606tq/569hp - 93 oct at 34 deg (207psi)
11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump
The Following User Says Thank You to GOAT8U2 For This Useful Post:
Old 03-22-2021, 11:24 AM
Bob with the 66's Avatar
Bob with the 66 Bob with the 66 is offline
X2,
I was told by a well known drive shaft manufacturer to keep C.F. shafts on the track and not on the street. Just a small nick could shorten it's life span and for MY build Aluminum was fine.
"Artificial intelligence is no match for natural stupidity".
1966 GTO Post Coupe, 467ci. N/A Pump gas, best 1/4 11.6 118mph
1966 GTO Post Coupe, "The Bright Idea" 535ci. N/A Pump gas, best 1/4 9.58 141mph
Old 03-22-2021, 11:40 AM
LOL!
They make high-end cars out of CF but we should run and hide from a CF driveshaft. LMAO
My take is not about durability, its about budget. The car is not a Top Sportsman car or a Pro-Mod therefore a CF driveshaft is just a waste of money to impress the uneducated at some car show.
Old 03-22-2021, 11:55 AM
Sirrotica's Avatar
Upon reading, the effects of heat on the CF, it says the sustained heat over 200 degrees will have an effect on the resin in the CF, and start weakening it.
On a street car it probably wouldn't be a stretch to have the temps reach over 200 degrees. I also read that some of the high end cars that use CF on the street have heat shields to protect the CF resin from exhaust heat, FWIW.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 03-22-2021, 11:57 AM
They make CF brakes and wheels as well, FWIW.
Old 03-22-2021, 12:31 PM
Sirrotica's Avatar
It's not the CF that fails, it's the resin used to bond the aluminum ends to the tube that fails. I have no idea of what resin is used on wheels or brakes, but I'm sure it's no the same resin.
I just read up on the failure criteria and reported what I read, I didn't engineer the parts. Don't shoot the messenger...........
I had a friend that raced late model stock cars that bought some CF wheels for it, and they also failed in use. A big investment that didn't pay off in increased performance, or longevity. He never bought any more of them.
There are also hybrid driveshafts that are an aluminum tube core that are wrapped with CF for reinforcement, so just looking at one someone couldn't tell if it had a aluminum core, or not.
Upon researching CF wheels, the early ones had failures due to heating. They then made changes to the resin and other components to keep the wheels from overheating, and ultimate failure.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 03-22-2021, 01:00 PM
RocktimusPryme's Avatar
I dont have a hard take on if you should or shouldnt use it. If OEMs are using it now in production HP street cars I would say fire away I guess. But reading this I feel like there is some misconception about the pros/cons of carbon fiber.
I worked for an Aircraft company that used carbon fiber hulls.
CF is incredibly strong structurally. We did a demonstration when I was in A&P school where we made a carbon wing section and an aluminum wing section then ran the both over with a truck. The carbon held up better.
What CF is NOT good at is handling small area impact. To give an example, most of us have been on an aluminum fuselage airliner. Most of us have flown through clouds. No problem. On the flip side, with the carbon fuselage UAVs I worked on, if you fly through clouds, the plane would come back down and look like it had caught the chicken pox during flight. Many clouds have small traces of hail in them. Those small ice impacts played hell with the fuselage.
Same thing with dropping a screwdriver. Drop a tool on a metal panel and maybe you get a dent. Do it on carbon and you probably get a hole. Anyone who worked on the planes I did for any length of time got that merit badge at least once.
How often does road debris fly up and hit the driveshaft? No idea. But a small rock impact could cause a weakpoint that an alloy driveshaft probably wouldnt notice that could lead to failure.
If nothing else I would think a CF driveshaft would require much more diligent inspection for mechanical damage.
The Following User Says Thank You to RocktimusPryme For This Useful Post:
Old 03-22-2021, 02:53 PM
I thank you. It surely feels a bit risky. QA1 is very confident of their product and thus far in my conversations with them the biggest immediate concern they seem to have is with heat. The person I spoke with described their product being used in off-road and dirt track applications but, one never really know if you're being "sold" on something. I have a bit of time...I'll continue to solicit comments and I'll keep doing some poking around on other forums.
1968 Firebird
IAIIa 522
340 E-heads
4L80E
3.50:1 Rear
Old 03-22-2021, 03:38 PM
Dragncar Dragncar is offline
I have been kicking around a CF drive shaft for awhile now. I just race my car so I do not think heat would be a issue.
But the damage I have seen from broken steel driveshafts can be horrific. Just about ruins the car in some cases .
I like the idea of the whole thing going "poof" if the worst happens.
Trying to fix major undercarriage/floorboard damage on these old 60s would be a major pain.
Its not like we can go down to the corner junkyard for donor cars anymore.
The Following User Says Thank You to Dragncar For This Useful Post:
Old 03-22-2021, 03:42 PM
Formulajones's Avatar
I would tend to think absolutely not on that comment because the driveline shop I deal with in town won't even build an aluminum shaft for the offroad desert racing trucks around here (let alone a carbon fiber), and he provides his service to hundreds of people running in various classes in the South West here.
His reasoning is that even aluminum doesn't like being hit with an obstruction, they will fold up like a prezel, so he builds "Steel only" for those applications.
With that said, and knowing he has a stellar driveline reputation out here spanning over 40 years, as well as in his own desert racing class, I just don't see a carbon fiber shaft even being considered for an application like that. As Rock said, they are structurally strong but they can't tolerate a small area impact at all. And in an off road situation it WILL get hit with debris.
https://youtu.be/XqEydRRRwqE
Old 03-22-2021, 06:08 PM
ta man ta man is offline
For the OP I would suggest going with a CM shaft..all CM inputs and yokes and call it done.
The Following 2 Users Say Thank You to ta man For This Useful Post:
Old 03-22-2021, 08:01 PM
That does present the fewest unkowns. Tried and true.
1968 Firebird
IAIIa 522
340 E-heads
4L80E
3.50:1 Rear
Old 03-23-2021, 01:48 PM
Will Will is offline
Originally Posted by RocktimusPryme View Post
What CF is NOT good at is handling small area impact. ....
This for me rules out CF in a street application.
I remember when I tried CF fishing poles. I loved the feel and the action I got from them but any little scratch or nick and the darned things shattered right at that point. Nothing like hooking a lunker and having your pole snap off as you're fighting it. The second time that happened the line got dragged across the broken section of pole and it cut the line. Nice big fish swam off with my lure and about 30' of line dragging behind it. Have NEVER broken a fiberglass/carbon composite pole which are almost as good.
After that I did some reading and discovered how notch/nick-sensitive CF is. Seems like a terrible idea for a highly stressed rotating member on the underside of a street car. I'll stick with aluminum or steel.
