Old 02-14-2021, 06:47 PM
62 bv 62 bv is offline
Default dash lights
hi i have no dash lights or turn signal lights i have no power to the dash light fuse holder on either side of the fuse but power to all other fuses any help new loom
Old 02-15-2021, 01:56 AM
Check parking light fuse. If I remember correctly power for dash light fuse comes from there.
Old 02-15-2021, 02:19 AM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Assuming this is a 64? Did you put the ground wire on the cluster housing? Also do you have the front park lights hooked up.
If you don't have front park lights hooked up, you may not get turn signal lights on cluster. Do the turn signal work in rear?
64 Lemans hardtop
4spd, buckets
