Old 02-02-2021, 04:42 PM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Default 1962 HEI Distributor fit
Will a full size hei fit fine or should I use a small body? Am I correct in assuming 1962 389 is the same as later years ?
Old 02-02-2021, 04:58 PM
TransAm400 TransAm400 is offline
I'm sure there are members with more knowledge than me but I know for a fact that a regular HEI would not clear an EP4B intake on my 64 389. I'm assuming a stock intake would be the same.
1979 TA 541/T56 Magnum
1964 Catalina 462/TKO600
1965 GTO 389/4speed
Old 02-03-2021, 11:51 AM
pfilean's Avatar
pfilean pfilean is offline
GM HEI will be a problem with tri-power. But there are some aftermarket small body units available.
Old 02-03-2021, 05:03 PM
that, and the Small body looks better and uses a proper coil.
