Master cylinder with 7/8" bore
What car model would have the above master cylinder....I want to improve my manual braking..front disc/rear drum. I currently have a 1".
george
What are you trying to mount it to?
77 Monzas have this diameter. |
Manual brake 67 gto
George
Is this a disc brake car, and if so what type of calipers?
George,
I fitted one to a 68 LeMans a few years. It was a Summit alum version of the factory c/iron unit. This car had a booster & owner wanted less pedal pressure. Did the job nicely. When I tried to buy another of these [ alum, 7/8"bore ] for a friend, I found Summit had discontinued them. However, some one else was making them, cannot remember the brand [ Wilwood? ] a little more expensive though; haven't checked in a long time, maybe Summit has re-instated them. |
Scarebird, stock ‘72 lemans calipers, with proportioning valve Replacing distribution block.
Geoff: I know Wilwood has alum M/C in that bore size but it’s pricey. Sure, it comes with the glam. George
I use a Mopar minivan master. 1984-98 that is 24mm. Aluminum, and you will need to fab a pushrod and elongate the ears but they are 26 dollars new and work well.
But the stock 1" bore should work fine manual. We did a 68 Firebird with the D52 calipers and reused the stock drum manual master - worked perfectly. |
Thanks Scarebird. I just think I could use some more pressure at the calipers. The 1" I have seems to work fine, just want to experiment with the 7/8" if readily available.
george
The issue now if you use a 7/8" bore is if you will have enough pedal swing to lock them up.
Thanx Scarebird, I took a quick look at rockauto, napa, etc. it seems a '77 Monza M/C is made of unobtainium or need $$ for NAPA new ones. I could throw more a bit more $ at it and get the fancy Wilwood if I'm going to do that. I just may rethink it for next season.
George
The Mopar unit on my TA does 4 wheel disc manual very well
George, don't be a scrooge...buy the Wilwood....it will look better & last longer.
Seriously, when I mentioned the Wilwood in my earlier post, I wasn't 100% sure of the brand, it was a few years ago. Could be other brands that are cheaper. |
