#81
I'm modifying the stock valley pans but the aluminum plate style works too. I'll show that soon. We'll eventually make our own Arrow Injuneering pans.
Randy Repp 1964 GTO "GoatZilla" 1964 GTO "Injunuity" A/FX Nostalgia Super Stock 220" Rear Engine Pontiac Powered Dragster https://www.facebook.com/PontiacSpeedShop/ https://www.facebook.com/GoatZillaRacing/ https://www.facebook.com/groups/RebuildExcitement/ https://www.facebook.com/Call1844RacersRV/ https://www.facebook.com/groups/INJUNWARS/ |
#82
I just ordered - Order ID #153
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears '69 LeMans Vert, 350, #47 heads: Non-running project |
#83
Wrapping up the install on my guide plate system today and I have a question.
The roller lifter has two flats, one of which lines up with the oil hole. I installed the lifter with the oil hole facing the oil hole in the block. I'm assuming that if the oil hole in the lifter faced away from the oil hole in the block, it would still get oil due to the ring around the lifter. I ask because I don't want to screw something up and two, when I was double checking the valve lash today I noticed that a couple of lifters would spin with the push rod and I'm not sure that the oil hole is lined up with the block any more. As for the system, it is pretty simple. I have it initially set and am going back to double check clearances between the lifters and plate one last time before torqueing it down. |
#84
Looking forward to your results - have you considered adjusting lifters with plate on?
You'll know it's on base circle is by using the following method: Exhaust valve STARTS to open, adjust the intake Intake valve ALMOST closed, adjust the exhaust Go cylinder by cylinder following this method, get them to zero lash, and give them a 1/2 a turn more, lock them down. Continue until all are done.
#85
I have mine all the way down. Maybe I’m doing something wrong. Good luck with the install! Anxious to hear how it goes. Murf |
#86
Has anyone ever tried making a lifter with a roller ball instead a flat roller. Seems like that would solve the problem of having them attached to each other so they don't spin.
#87
The load on the ball would be much higher because of the very small area of contact with the cam.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
#88
Adjusted lifters using the method outlined in Jim Hand's book How to build max performance pontiac v8's. Started with the motor at #1 TDC and adjusted #2 intake and #8 exhaust. I followed the order in the book every 90 degrees of crank rotation until they were all done. It called for zero lash and then a 1/4 turn which is what I used. That all went smooth. I did all of this without the plate in place..
When I went back to double check them all, I spun the push rods in the same order I set the valves so that the lifter was sitting on the base circle and the lifter would actually spin on the base circle as I spun the push rod. Can anyone please confirm that the oil hole in the lifter does not have to be directly in line with the oil hole in the block, that it is okay if it is 180 degrees away??? I'm working on the plate now. I started with the adjustment nuts all the way down. This was too tight as the lifters would not clear. I have been working it up slowly checking with a feeler gauge as I went. I marked the clearance on the plate with a sharpie as I went. I got them all where I wanted them and then torqued down the locking nuts and it changed the clearances. I reset them all again making sure the lock nuts were in place as I set them the second go around. The number 3 exhaust lifter has proven to be the limiting factor. With it at .002 clearance all the others are .006 to .008 with a few on the ends at .012. The .012 is a little bigger than I would like but if I tighten up those clearances, the #3 exhaust lifter does not clear. Be glad to hear the results of others. When I turn the crank by hand, everything looks good in the valley pan. |
#89
Edit to add, I went back & reread your post saying you have roller lifters. I don’t understand what could be going on. Maybe some pics would help. Are you doing this with a flat tappet cam? I don’t understand how this I’s happening with a roller lifter. I don’t know what purpose the plate would be serving with a flat tappet cam.
I’m sorry if I’m being dense but the whole idea of the plate is to keep roller lifters from rotating in the bores. Murf Last edited by Murf; 10-25-2021 at 05:41 PM. |
The Following User Says Thank You to Murf For This Useful Post: | ||
#90
One question at a time.
Does the orientation of the oil hole in the roller lifter matter? The lifter could spin because the plate was not in place. |
#91
No, that whole channel in the lifter body has oil supplied to it.
Again, I’m sorry I misunderstood your original post. Let us know how it goes! Murf |
#92
Correct - spinning lifter doesn’t matter re oil hole as flat tappets spin by design so shouldn’t matter with rollers. That being said - I also don’t understand how your roller lifters are spinning in bores?
Re: the clearance, when in Norwalk Randy explained that there may be tight spots on some linters. In this situation if other clearances are ideal, you should carefully grind/sand the plate in the tight area(s) to fine tune the clearance.
#93
Thanks. That is what I thought.
Now on to a discovery I made tonight. When the lifter is down on the base circle, the lifter does not contact the plate and can spin in a full circle quite easily. I was curious if anyone else running the plate system had noticed this? My concern is what keeps the lifter from wanting to spin when it is at zero lift. I sure would like to see the lifter in contact with the plate at all times, not just under lift. I've got a phone call in to Randy and will let everyone know what he says when I hear from him. |
#94
IIRC, In an earlier post the size of cam base circle was discussed and the range it would need to be in to avoid the oil band riding too high or too low. Can clarify if you’re using roller or flat tappet lifters?
#95
Tom V.
#96
Sorry. A little more info. I have the plate, roller lifters, and cam all as a kit from Randy.
When the lifter is at its lowest point, the lifter is below the plate and there is nothing physical to keep it from spinning. I spun a lifter in its bore slightly to see if it would self correct as it traveled up the lobe and if it is off axis enough, it will bind on the bottom of the guide plate. My concern is what would prevent the lifter from wanting to spin at the bottom of its travel. They stay true spinning the motor by hand but in use I would imagine the forces and momentums at play are different. I just want to make sure everything is correct before firing anything up. Thanks grivera for the info about possibly needing to do a little grinding for final fitting. A little fitting on #3 will allow me to get more uniform results across the plates. I'll try to get some video's tomorrow to better explain what I'm seeing. |
#97
Does any of this information help with your situation? What are the full specs of the cam you're using?
#98
https://www.facebook.com/randy.repp....20566339326493 You can see in this video that the lifters on base circle are dropping below the plate also.
#100
Thread Tools | |
Display Modes | |
