Any body ever do this on a 69 Firebird? The hole in the firewall is 2" circle. The plate the give you is 2"x 2.5". I was thinking about drilling a hole in a 16 ga piece of metal about 1/4", hole sawing about the same size hole in the metal around the 1/4" hole, then hole sawing the same size as the hole in the firewall. Then welding it to the firewall, drilling the hole as big as I need for the new pushrod, then drilling the four holes for the mounting plate. The hole really may not be strong enough without a full weld. As it is right now the hole in the firewall would have four ears on it, two on the top and two on the bottom....a little thin in the skin. What say ye? Thank you!!!
" Is wearing a helmet illegal" Mike Kerr 1-29-09 |
Bowler transmission makes an adapter that bolts behind the master cylinder that puts the Wilwood master pushrod in line with the factory pushrod home and hides the master under the brake master. I will get a pic when I get home
I originally mounted my “adapter plate” for the wildwood MC to my firewall. I found too much flex and made an additional support to the frame rail. I imagine using the brake mc as support will work also.
462 Yc Block, zero deck Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR Comp Hyd-roller cam,roller lifters,springs ect. 236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6 Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut Powerjection3,T2 manifold, Try-y’s Flowcooler water pump. 71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire. 17x9 YO Honeycombs with Nitto 555's |
Contact bowler transmission. My bracket is so “hidden” I can’t even get a picture of it
I got that plate when I put an American Powertrain kit with T-56 in my 69 firebird.
I thought the plate was too small, so I made my own larger plate so that the pressure would be more distributed throughout the firewall when the clutch was depressed. My plate went up between firewall and where the clutch/brake pedal bracket goes through the firewall and bolts to the brake master cylinder, then down and around the hole where the steering column goes through. There is much less flex when I press the clutch that way. Also the plate I got from American Powertrain really didn't have a big enough hole for the clutch rod to pass through without the threaded part hanging up on the sides of the bracket as it went in and out. |
Good ideas! Thanks guys!! I got as far making the patch.
I’m telling you look at the bowler transmission adapter. You won’t be disappointed
I certainly will! I guess it doesnt latter that you have the an original booster?
I ordered the bracket today. I wish I would have bought the conversion from them.
The bracket is awesome
