Old 11-17-2020, 02:44 PM
Indian Fixer Indian Fixer is offline
Default Need '65 Bonneville POSI-traction HELP!
Working on '65 Bonne Convertible 421 Tri-Power, THM400, 3.08 open rear end. Looking for a POSI unit and possibly a 3.42 ring and pinion. Best I can tell this is a heavy duty rear end, it has a 10 bolt cover, but it has 31 spline axles, the ring gear is 8.5", there are 12 bolts on the ring gear,and it is NOT a C-clip rear end, it has retaining plates at the ends of the axle housing. I've been poking around the aftermarket but can't come up with anything. Any ideas or what do you have for sale?
Old 11-17-2020, 05:07 PM
marxjunk marxjunk is offline
no aftermarket gears or posi available...you will have to buy parts or a complete rear and no one will prob pull a complete rear apart..
run a wanted add and see what pops up
Mark..
The Goat whisperer
"I spent a lot of my money on booze, crazy women, and fast cars. The rest I just squandered."
Old 11-17-2020, 05:44 PM
mgarblik mgarblik is offline
65-70 full size Pontiac. There is a fair supply of parts out there for these used of course. Clutch plates interchange with many other Eaton style limited slip units. Gears and posi-cases are a little hard to find but out there. It's possible Fabcraft still has some ring and pinion sets for them. They used to have some in addition to the 9.3" stuff. Looked on their site. They have a 3.55 gear set listed but out of stock. Sounds like if enough interest, they will run a batch. They also have a rebuild kit for the Eaton Posi and axle bearings. The one you would still need is a limited slip case.
Old 11-17-2020, 05:58 PM
stevep's Avatar
stevep stevep is offline
I recently sold a complete 65/66 3.42 posi rear for $1500.00
Old 11-17-2020, 09:17 PM
wow..i have 2 3.42 posi's drum to drum ive been sitting on...may be time to turn them
Mark..
The Goat whisperer
Old 11-17-2020, 10:41 PM
Only need one! Kansas is a long way from PA, but let's see what we can do. I haven't been on this forum for a LONG time but I guess there is a PM feature?
Old 11-17-2020, 10:52 PM
PM sent...
Old 11-18-2020, 03:33 PM
got it..let me kick it around, both still under cars...and they are behind 3 layers of cars..against the walls in my shop..major move to get them to the lift
Mark..
The Goat whisperer
Old 11-18-2020, 04:49 PM
Awjeez....my customer just called and said forget it! Gotta love it. Sorry man....
Old 11-18-2020, 10:48 PM
no worries...thats how it goes sometimes...
Mark..
The Goat whisperer
Old 11-22-2020, 03:55 AM
lust4speed's Avatar
If I blow up the 3.42's in our 2+2 I know who to contact now.
Two other things, the ring gear diameter is 3.875" which is the same as a 12 bolt, but totally different and doesn't interchange. The other is the Fabcraft 3.55" ring and pinion were designed to fit a Series 3 carrier which was originally for the 2.93, 3.08, and 3.23 ratios. They said that carrier was the most plentiful so they made their gearsets to fit that unit.
I purchased the Fabcraft 3.55 gearset when they first brought them out and the box is sitting on a shelf, and just recently went back to Fabcraft and purchased a billet pinion yoke, bearing kit, and other parts. The Fabcraft guys are very friendly to talk to and will spend time answering questions. Eventually the rearend will be going in the '65 Safari wagon.
Mick Batson
1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon.
Old 12-18-2020, 10:58 PM
mjm421's Avatar
mjm421 mjm421 is offline
Just to get this correct, if I currently have a 3.23 gear, the Fabcraft 3.55 will fit?
Mike McCarty You can drop the line, but you'll never kill the spirit!
Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far
Old 12-18-2020, 11:35 PM
lust4speed's Avatar
Definitely call Fabcraft. The below chart contradicts the previous information and looks like it would be a series 2 carrier that is needed. Moot point until Fabcraft runs another batch of 3.55 gears. Their website doesn't state what is needed: Fabcraft Metal Works
Here's a list of the Pontiac carriers:
1965-1970 Rear End Information
Gear Set Usage By Carrier
Year Case P/N Ratios Supported Notes:
1965-69 9784645 2.29 2.41 2.56 Except Locking Differential
1965-69 9784646 3.08 2.73 2.93 Except Locking Differential
1965-69 9784647 3.23 3.42 3.55 3.73 3.90 4.11 4.33 Except Locking Differential
1965-70 9779041 2.29 2.41 2.56 Locking Differential
1965-70 9779042 2.73 2.93 3.08 Locking Differential
1965-69 9779043 3.23 3.42 3.55 3.73 3.90 4.11 Locking Differential
Mick Batson
Old 12-21-2020, 04:26 AM
lust4speed's Avatar
Heard back from Fabcraft today - Sunday. These guys are great. Here's Dave's response:
MICK
YOU ARE RIGHT ON THE MONEY WITH THE CORRECT CARRIER -- SERIES II ( WHICH WAS FOR 2.73 TO 3.08 OEM GEARS )
WE ARE HOPING TO MAKE ANOTHER RUN OF THE 3.55 GEARS AND ALSO HOPE TO HAVE A NEW POSI AS WELL SOMETIME IN THE FIRST HALF OF 2021
GLAD THAT 2020 IS ALMOST BEHIND US
BE SAFE - BE HEALTHY - HAVE A MERRY CHRISTMAS !
DAVE
I blew it on my original response (post #11) by quoting an internet site that listed the wrong split on gears for the '65 big car that tossed the 3.23 gearset into the wrong carrier group.
Mick Batson
Old 12-28-2020, 05:26 PM
ken66 ken66 is offline
I’ve got two of those posi carriers (both currently sporting 2.73s). Looking forward to 3.55s...
