Old 11-08-2020, 11:42 AM
PontiacMatt72's Avatar
PontiacMatt72 PontiacMatt72 is offline
Default Share your 500”+ *STREET* engine cam info
Looking to get a list of big (500+”) *street* engine cam info to get a feel for the range being used in our engines. Street car = car is street driven. Street/strip is fine, long as the car is street driven.
Please list:
Cubic Inches
Cam design (hydraulic/solid, flat/roller)
Cam duration- “advertised“
Cam duration- @ .050
Lobe lift
Compression
Transmission
Rear gear
If dyno’d, share results if you’d like
Bonus points for pic of engine in car.
Chit stirring = point deductions.
Matt
70 GTO 400 4-speed
"Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge
Old 11-08-2020, 12:46 PM
getmygoat's Avatar
You are asking folks to do a lot of work. Here's one example (motor in my judge):
http://forums.maxperformanceinc.com/...ighlight=judge
1969 400 RAIII block, .040" over at 4.160". 408CID
Stock crank
RPM I-Beam rods
Icon 14cc dished pistons, forged
1/16"x1/16"x3/16" plasma Moly rings
#48 heads, CNC ported by Dave at SD Performance. Flow at .500" was around 254/214'ish
9.5:1 compression
Ferrea 2.11"/1.77" SS valves
Valve spring pressure = 155-160 lbs. on the seat, and around 400 open
Factory cast iron Q-jet intake, ported
RAIII Q-jet, rebuilt[A/F ratio's were real nice, in the mid to upper 12's in the mid to upper rpm range
Lunati Voodoo hydraulic roller cam, 227°/233° @ .050", 278 °/282° Adv., 110° LSA, .530" lift, degreed to 105° ICL
Hylift/Johnson slow bleed hydraulic roller lifters
Harland Sharp 1.5 ratio roller rockers
8.800", .083" wall 1 piece pushrods
Stock points distributor with Petronix conversion
Factory RAIII exhaust manifolds with stock openings, and a 5' long, 2.5" pipe bolted on.
Dynoed with 91 octane pump gas. These numbers are with 32° total timing. We tried 34° and it made slightly less torque and HP. Just for S&G's, we tried 36° and it made the most hp[461 @ 6000 rpm], but torque was down a little. 32° gave us the highest peak torque, as well as the highest average torque, and HP of the 3 different timing events. At 32° timing it made 475 ft. lbs., and 454 HP peak.
The Following User Says Thank You to getmygoat For This Useful Post:
Old 11-08-2020, 01:08 PM
1968GTO421's Avatar
How does this differ from B-man's thread on engine builds? It would save someone time from having to sort through all the builds looking for 500+ inch engines but I haven'tcome across that many500+ builds on this street section. If you haven't looked at B-man's thread, it was started in 2007 and some big builds on it are done by folks who haven't posted in years so you would find info that wouldn't appear in this thread, Just sayin'.
http://forums.maxperformanceinc.com/...d.php?t=520102
(Member GTO JONES has one of those 500+ inch monsters and could be a good source of info if he doesn't see this thread.
http://forums.maxperformanceinc.com/...r.php?u=147940 )
GTOAA--https://www.gtoaa.org/
Old 11-08-2020, 01:14 PM
i82much's Avatar
i82much i82much is offline
65 GTO hardtop.
M23 ultra wide muncie
3.54 Strange S60, 28 inch tires
87 cc old round port e-heads, ported with 2.19/.77 valves
Performer RPM, 850 quick fuel double pumper (very similar to a 4781)
IA2 block, 505 CID
eagle forged crank and 6.8 h beams
BRC 2618 pistons
Approx 10:1
MSD Ready to run with programmable 6AL2
Old Faithful 1.0 with Comp hyd roller lifters
Rev limiter set at 5500
Pure street car. Never been to a show or the drag strip, maybe never will. Take it out on country roads after the kids go to bed and get my giggles. I have some things to do to clean up the engine compartment but it runs great and I am making progress on the little things.
Old 11-08-2020, 01:16 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Most info is in the signiture.
4.35x4.350 bore & stroke.
Potential for much more power with carb, cam, compression changes but fits the definition of a street car that can be driven across the country on pump gas.
Starts at the touch of the key, idles at 800 in gear and drives smooth at low speeds. At this time I’m not willing to give up any of that drive ability for more power, it has enough.
Biggest drawback is it’s a death trap with normal street radials, stick DOT tires required.
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
The Following User Says Thank You to TCSGTO For This Useful Post:
Old 11-08-2020, 01:18 PM
Steve C. Steve C. is offline
Seeking 500 and up horsepower builds, this one just squeek's by with 502.4 hp at 5300 rpm. Dyno sheet included.
https://pontiacstreetperformance.com...d455MikeG.html
Old information here:
Old 11-08-2020, 02:29 PM
ID67goat's Avatar
ID67goat ID67goat is offline
Are you looking for 500+ cubic inch combos or 500+ horsepower combos?
Old 11-08-2020, 02:34 PM
500”+ or 500+” means 500 inch plus or 500 plus inch. So 500 cube or larger engines.
Not 500+ horsepower, though one would expect most would be making at least that much with a 500” plus combo.
Old 11-08-2020, 02:39 PM
ID67goat's Avatar
500” + means 500 inch plus.
Not 500 horsepower.
Oops...I missed the (") in the title....and the first combo posted had me a little confused. Thanks.
Old 11-08-2020, 03:17 PM
I asked myself the same question... HP or cubic inches ! I also spaced the "inch" mark after the 500.
Old 11-08-2020, 05:59 PM
getmygoat's Avatar
I thought he was looking for more than 1/2 inch of lift in the cam (e.g. .500"+ engine CAM info).
Old 11-08-2020, 06:03 PM
No decimal point.
Big 500”+ engine cam info.
Old 11-08-2020, 08:31 PM
Formulajones's Avatar
There are quite a few very successful 500+" Pontiac builds that are street driven. Couple guys I know don't post in here however.
Dad's combo has been doing it for I think going on 7 years now.
571 ci with a 4.350" bore and 4.750" crank. An old set of ported Edlebrock round port heads, 10.84:1 compression. Started off with a custom solid roller with 269/279 @ .050 and .703/.711 lift, on a 110 lsa. The combo made 724hp/764tq with the chassis headers and 4150 carb on 91 pump gas.
He later switched to a custom hydraulic roller with 261/265 @ .050 on a 112 lsa and I think the lift is in the .660's but I don't have that card in front of me at the moment. I do remember this one being a Harold designed lobe, partially from the newer Voodoo profile on the intake side and the older Ultradyne profile on the exhaust side that Paul Carter spec'd to mimic the solid roller. This cam is also a 4-7 swap.
The rest of the car is simple. 400 turbo, custom converter, 3.42's out back, full exhaust system and all the creature comforts the car was born with when dad bought it new. 100% street car and driven everywhere.
It's actually surprisingly docile, runs cool, idles all day long and does 300 mile road trips in the AZ heat without complaint, and routinely climbs up and down the mountain passes here in Northern Arizona. It's been a fantastic engine.
https://youtu.be/XqEydRRRwqE
Old 11-08-2020, 08:50 PM
Slick Poncho Slick Poncho is offline
72 lemans sport 505CI mr1 block scat crank, eagle arms, Ross pistons, KRE 310 dports,10.8 compression, 93 octane diet, bullet 264-270@50 110lsa solid roller .690ish lift,Holley super sniper efi, 4l80e with custom built lockup Converter , flashes to about 4k .12 bolt 3.90 gear. Cruises at 80mph nicely with converter locked up. Ordered a set of SD 340+ Heads to hopefully install the winter.
Old 11-08-2020, 10:15 PM
sjdiesel's Avatar
sjdiesel sjdiesel is offline
Subscribed
Sean
1967 GTO
Koerner built 468 with Edelbrock RP’s 315cfm by Butler, Luanti Voodoo HR 20510713, 4l80e, Holley Terminator EFI
Old 11-08-2020, 11:26 PM
SS-TA SS-TA is offline
http://forums.maxperformanceinc.com/...d.php?t=797155
Old 11-08-2020, 11:35 PM
Sorry for the confusion... yes, referring to 500 cubic inch “plus” (and bigger) engines. I appreciate all the effort, the more info the better. But if it helps simplify it, an example of what I’d like to see would be:
535 cid
Hydraulic roller
304/310 advertised
260/268 duration @.050
.400 lobe lift
10.5 compression
M-22 4 speed
3.73 gear
But, no harm in sharing more if you are able/willing!
Also, I’m aware of b-mans thread. Just specifically curious about big inch engine setups.
Matt
70 GTO 400 4-speed
Old 11-09-2020, 07:41 AM
IA2 block / 505 CID
Edelbrock cylinder heads / about 320 cfm at .700" lift
10:1 compression
Victor intake / 1-inch open spacer
( Intake carb flange milled down 0.650" for additional hood clearance, therefore closer to 1/2-inch open spacer for dyno testing )
Precision Racing Components custom Holley HP950 carburetor
2-inch headers
Current cam is a Ultradyne solid roller
.020 288/292
.050 255/259
0.4176" lobe lift / 1.65-1.6 rocker ratio / .022" lash
110 LSA / 106 ICL
Depending on the pull, it's now a 625-630 HP engine.
The best number was 635 HP.
Peak torque at 4400/4500 rpm and peak power at 5700/5800 rpm.
Start of the recorded numbers at 4100 rpm the torque was 627/628 ft.lbs.
It carried over 600 ft.lbs torque from 4100 rpm up thru 5400/5500 rpm.
We dyno'd with the same intake manifold and carb as used before a recent cam change was made. But I'm now running direct port fuel injection.
The shop was not equipped to dyno with my FI system.
Outdated but further info on car:
https://www.hotrod.com/articles/0712...tiac-trans-am/
Old 11-09-2020, 07:59 AM
steve25 steve25 is offline
With a NA 400 cid street motor if its 500 plus hp your looking for such a motor can be built , but it will be very undrivable !
I would put the limit at 475 hp to be realistic.
Old 11-09-2020, 09:42 AM
slowbird's Avatar
slowbird slowbird is online now
Totally wrong we've had a 500+hp 400 on the street for many many years and it's very streetable. Would be even more street friendly with a good set or aluminum heads vs our crappy iron heads.
But this thread is not about 400s making 500hp
The Following User Says Thank You to slowbird For This Useful Post:
