Old 10-31-2020, 01:14 PM
Hotrodjohn71 Hotrodjohn71 is offline
Default Please help identify transmission
Hi. I got this transmission with a 1967 firebird project but I need to identify it so I can obtain the correct transmission cross member. I can't find the tag # on Google. Can you help? Thanks
ID:	552668   Click image for larger version
ID:	552669   Click image for larger version
Old 10-31-2020, 01:23 PM
You are not leaving anything to go on. Could be anything from soup to nuts. At least post a photo of the pan.
Old 10-31-2020, 01:26 PM
Thank you Chief. My apologies, I clicked 'Post' before adding photos. They should be there now.
Old 10-31-2020, 01:44 PM
That’s a long tail shaft TH400 from a B-body big Pontiac.
I’d be looking for a short tail shaft trans. Otherwise you’re paying extra to shorten the driveshaft. The proper crossmember for a short shaft TH400 is readily available. To use the long tail shaft trans you can move the crossmember rearward and drill new holes I suppose, but again a custom length driveshaft is needed.
I would definitely find a short shaft trans, the driveline angles aren’t really ideal once you shorten the driveshaft to compensate for the incorrect long tail shaft trans, otherwise the factory would have used the long tail shaft trans to begin with in the F-body Firebird and A-body GTO/Le Mans/Tempest.
Old 10-31-2020, 01:49 PM
Thank you b-man for the info. I will definatly sell this one and get a short shaft th400. Will any short shaft th400 bolt up to my pontiac 326 do you think? Thank you
Old 10-31-2020, 02:16 PM
As long as the bellhousing on the new trans you find is BOPC (Buick/Olds/Pontiac/Cadillac) bolt pattern like the trans in your pictures it will bolt up directly.
A Chevy bolt pattern trans will work if you use an adapter plate, but the more popular Chevy transmissions are more expensive usually compared to ones that bolt up to a Pontiac.
Old 10-31-2020, 02:57 PM
Scott Thelander's Avatar
agree with B-man th400 long shaft POB
another item to think about ..
is the UNIQUE th400 dip stick and tube for the 67-9 Firebird, you will need
that may cost as much as the th400 core
Old 10-31-2020, 03:04 PM
Thank you for the valuable info. I really appreciate it. I've always been a Ford man but I decided to get this 67 firebird as a surprise Christmas gift and I'm not totally familiar with GM.
One more question if I may. Does this photo look like what the t400 should look like that I need for my firebird? Thank you
Name:	Screenshot_20201031-115701_Samsung Internet.jpg
Old 10-31-2020, 03:10 PM
1968GTO421's Avatar
The pic did not enlarge well on mine, but yeah that certainly looks like a short tail TH400 to me. Doesn't have a bolt hole at top of bellhousing so I'm sure its a BOP TH400. Go for it.
GTOAA--https://www.gtoaa.org/
Old 10-31-2020, 03:27 PM
That’s a short tail shaft TH400 but it’s for a Chevy.
I’ve enlarged your picture below. Next to it is a picture of a short tail shaft Chevy TH400 I have sitting in my garage, you can see both are the same.
As already mentioned above you’re going to need a compatible dipstick tube and dipstick. I recently installed a short tail shaft TH400 from a ‘70 GP into a ‘68 Firebird that I recently sold, the ‘70 GP dipstick tube fit perfectly so I’d bet any ‘69’- ‘72 GP dipstick setup would work.
ID:	552684   Click image for larger version
Old 10-31-2020, 03:35 PM
Do you know what auto trans was stock in the 67 firebird behind a 326? Was it a t350? I appreciate all of your advice?
Old 10-31-2020, 03:46 PM
The ST-300 2-speed was used behind the 326. A TH350 bolts directly in place of the ST-300, super easy swap.
Old 10-31-2020, 03:54 PM
Thank you b-man. Then that settles it. I'm going to sell this Turbo 400 and get a T350. This is a surprise gift for my wife. Doesnt have to be a race car.
The Following User Says Thank You to Hotrodjohn71 For This Useful Post:
Old 10-31-2020, 05:35 PM
Half-Inch Stud's Avatar
OA-69 That is a 69 Olds Big Car TH400; BEST GUTS EvER! And Best Case.
I have a few SPARE short-tails shafts and cups. Go TH400 Short-Tail and you will be glad ya did
Old 10-31-2020, 06:53 PM
Dragncar Dragncar is offline
I have run a long shaft T400 in a 69 GTO forever. The drive shaft was shortened, but it was one custom made for a short shaft Ford Toploader transmission.
Old 11-01-2020, 07:25 AM
East East is offline
Default Passing gear/kickdown cable TH350
TH400 kickdown switch
TH350 kickdown cable to carb
Old 11-01-2020, 08:26 AM
sdbob sdbob is offline
Some of the cases where they bolt to block have a inside rib that reinforces those top 2 bolt holes. I'd keep,just me, and rebuild with short shaft and tail housing. Bought those parts from cliff last year. Trans in race car was a long shaft rebuilt to short.
Old 11-01-2020, 08:29 AM
chuckies76ta's Avatar
You can just use the short tail housing and output shaft on the TH400. I would keep that TH400 Tranny if I were you. Those are the strongest TH400 cases made by GM. They have the metal vent tube, support ribs on the bellhousing, 8 bolt pump, and the pan rail is thicker. The output shaft area is also beefier.
Charles
The Following User Says Thank You to chuckies76ta For This Useful Post:
Old 11-01-2020, 12:32 PM
Thank you for your suggestions and advice.
Does this look like a TH350.? It is from a 77 trans am.
Old 11-01-2020, 12:34 PM
Yes, TH350 with the BOPC bellhousing.
