Old 10-17-2020, 02:31 PM
nytrainer's Avatar
Default Need connectors for conv top motor
I put in relays for my headlights on one of my 68 Lemans’ (works great and lights are SO much brighter) and finally got around to put in relays for the convertible top circuit.
I was able to get creative with the headlight circuit as to not cut up or alter original harness and would like to do same for top motor.
So I separated the harness clip by the top motor and would like to buy the same connectors so I can feed my relay panel (And then connect output of relays to motor) without cutting into the harness wires. That way I can return to original if need be for a future owner.
Here’s what the connectors look like. I will use spade connectors if I can’t find originals or new connectors that fit these.
Thanks.
ID:	551617   Click image for larger version
Old 10-17-2020, 03:26 PM
Stuart's Avatar
Stuart Stuart is offline
You could check with https://www.lectriclimited.com - I took a quick look and it appears they only show wiring harnesses on their website, but it may be worth a phone call to see if they'll sell individual connectors.
The Following 2 Users Say Thank You to Stuart For This Useful Post:
Old 10-17-2020, 04:46 PM
Scott Thelander's Avatar
I will send a pair Monday
pm me your info
Scott
pics tomorrow afternoon Im not home we are at the ocean clam digging
Old 10-22-2020, 04:21 PM
nytrainer's Avatar
Still looking...
Old 10-22-2020, 06:16 PM
OG68 OG68 is offline
Here are a few places that I order from;
http://www.delmarwire.com/home
http://www.texasindustrialelectric.c..._terminals.asp
https://www.wiringproducts.com/gener...ectors-sockets
2007 Cadillac SRX
The Following 2 Users Say Thank You to OG68 For This Useful Post:
Old 10-28-2020, 06:24 PM
dataway's Avatar
dataway dataway is offline
Thanks for the links folks. Timely post, I'm in the same boat, want to do some rehab on my 68 harness and I'll probably need a few connectors.
I'm assuming the harness building companies have a source for these parts, they probably don't manufacture them in house.
Also ... anyone know where to get color coded wires to match OEM colors? My harness is in decent shape but will need some individual wires replaced and I'd like to use original color wires.
Old 10-28-2020, 06:51 PM
dataway's Avatar
Found what looks like a good source for code wire, pretty much any color with any tracer color.
https://www.ynzyesterdaysparts.com/
Still not much lucking finding application specific connectors based on year/model etc.
Old 10-28-2020, 09:55 PM
Ran across this today in my search for a certain type of connector.
https://jcaparts.com/collections/pon...ector-housings
M & H also has wiring. Scroll down to the end of the harness section
http://www.wiringharness.com
2007 Cadillac SRX
Old 10-29-2020, 02:15 AM
kk68's Avatar
kk68 kk68 is offline
Readily available on eBay. Search for Packard GM connectors, I think series 56. Added relays for my pwr convertible top switch as well.
Don't rush me - it's only year 20 of the 3 year restoration!
68 GTO convertible
YS M40, A/C, PS, PB-disc, Posi-T, PW, P-seat, AM-FM stereo 8-track,
P-ant, P-trunk lid, Tilt-S, Rally gauges, Hideaways
C1 224 Triple white
The Following User Says Thank You to kk68 For This Useful Post:
Old 10-30-2020, 02:19 AM
dataway's Avatar
Freakin excellent, thanks people.
Old 10-30-2020, 02:39 AM
Default update
went to my old wrecking yard today to pull parts off a 64 starfire
that just came in .. power window power wing window power antenna car
vacuum trunk
cut the plug n wires off a caddy convert pump motor from late 60's
and the end off the power floor harness
female plug is tattered ..... male is fine
other is a spare I had
Scott
upper left and lower right are buddys from the caddy
lower left is a spare ,,,, junk lock latch on that female also ... I may have a spare
if you still have a need
The Following User Says Thank You to Scott Thelander For This Useful Post:
Old 10-30-2020, 11:33 AM
nytrainer's Avatar
Curious where you mounted your relays? I used the factory Convertible top wiring to trigger the relays which are mounted on a small aluminum panel I made which is then attached to the metal structure behind the upper rear seat. The power through the relays to top motor are supplied by a fused 10 gauge wire I ran along the original floor harness.
I toyed with doing it a bit different at first by mounting the relays under the dash but with an A/C car there wasn’t much room.
Old 10-30-2020, 11:43 AM
nytrainer's Avatar
vacuum trunk
Scott
I ended up keeping my “temporary” connectors (shrink wrapped and soldered 10 gauge male and female spade terminals). It didn’t require cutting original harness. The difference is motor speed/performance is amazing.
I plan on doing same mod for my other ‘68 convertible so if you can locate a male and female connector with wires attached I’d prefer using those and I’d still take them.
Old 11-01-2020, 01:01 AM
dataway's Avatar
I just got a variety of tools for removing the wires from the plugs, work pretty nice. Can take a bit of fiddling but the wires do come out. Eventually I'll look into getting the tool to put new metal connectors on the ends of the wires.
With the right tools you can basically make all kinds of harness repairs and modifications without any mid-harness splices.
Old 11-01-2020, 02:21 AM
Default and
pulled a plug off a courtesy light harness
I used my small screw driver to push the tab and wire pops out,,
Old 11-02-2020, 02:12 AM
dataway's Avatar
See, even Scott can almost do it
Old 11-02-2020, 02:02 PM
kk68's Avatar
I mounted my relays hidden behind the upper left corner of dash to protect the convertible top switch which commonly burns out. I'll try to find a pic or two to post. I'm sure behind the seat will work just as well.
68 GTO convertible
C1 224 Triple white
Old 11-03-2020, 12:34 AM
kk68's Avatar
Here’s some pics I had, not the best, but hopefully help.
First pic should be turned clockwise 90 deg.
ID:	552958   Click image for larger version
ID:	552959   Click image for larger version
68 GTO convertible
C1 224 Triple white
Old 11-03-2020, 09:16 AM
nytrainer's Avatar
Looks professional KK!
I might have gone that same route if I had the dash apart and could go in from the top (AC car) so that’s one reason I placed relay panel on upper back seat structure.
I was replacing the carpet and putting down some hush mat so I took the opportunity to send a 10 gauge feed wire alongside the rear harness. I wanted to have power in the trunk to feed a couple of other relay circuits anyway (light, trunk release, and hidden LoJack).
With age the original circuit had a voltage drop and always seemed the motor would struggle to get through the lifting operation. Now it runs up/down effortlessly. Also not the best idea to make/break high current circuit with a switch. Pits the contacts and increase resistance. Switch now has it easy as it passes low current just to pick up the relays.
If anyone wants photo and/or explanation I’d be glad to share.
Thread Tools
Display Modes
