Old 10-11-2020, 12:44 PM
BLACK70GTO's Avatar
BLACK70GTO BLACK70GTO is offline
Default Pontiac Mini Starter
Just wanted to see what mini starter everyone is using??
Anyone better than the other???
Old 10-11-2020, 01:14 PM
76TA462 76TA462 is offline
I have been using a Powermaster 9610 since 2010. Car starts great.
Old 10-11-2020, 03:39 PM
janderson's Avatar
janderson janderson is offline
Have used the power master 9510, no complaints.
Using GPE on other car, good people and quick turnaround if you need a rebuild.
Old 10-11-2020, 04:24 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
We've has good luck with the Powermaster XS Torque Starters 9510 as well.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 10-11-2020, 04:30 PM
BLACK70GTO's Avatar
Default Starter
I've had the same mini starter on the car for about 10 years, Had it rebuilt a few times, just put a solenoid on it.
When I hit the starter button just clicks, after I hit it a few times it will start the car.
Any ideas??
Old 10-11-2020, 04:41 PM
Gary H's Avatar
Gary H Gary H is offline
I only use IMI starters on my own car, and my customers cars. Great product and price.
The Following User Says Thank You to Gary H For This Useful Post:
Old 10-11-2020, 04:56 PM
Dragncar Dragncar is online now
I have had a Summit mini starter for years, never a hint of trouble.
Thing is, most all of these mini starters are copies, as most things in the automotive world are, German origin. The Bosh starter which all the Japanese companies, Denso and the rest copied, then China copied it.
That original Bosh starter the solenoid is the weak link as all the copied versions, the Pontiac mini starters. My Tundra has a copied Bosh starter and the solenoid went out. So I replaced it.
The Summit/Bosh mini starter on my GTO has never given me a problem because I have always ran a Ford solenoid with jumper wire so it takes all the electrical hit first. Its the only way to go. Cheap, easy to change and if it ever gives me a problem I can jump start it with a screwdriver at the track. All the mini starter solenoid really needs to do is kick the starter drive out into the ring gear as the motor has already started spinning and the Ford solenoid got it going and took the hit.
You used to be able to get contact kits for the bosh style solenoids but now hard to get and they are crimped anyway so you can not even take them apart to service if you wanted too.
Summit mini+ Ford solenoid will work for 95% of us unless you need a nose support.
The Following User Says Thank You to Dragncar For This Useful Post:
Old 10-11-2020, 11:39 PM
MidnightAuto's Avatar
MidnightAuto MidnightAuto is offline
IIMI here too. No issues. Fixed heat sink problem
Old 10-11-2020, 11:42 PM
67GTONUT's Avatar
67GTONUT 67GTONUT is offline
Powermaster XS Series...... love it
Troy
Rockaway NJ
67 GTO
400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI
HOTCHKIS/UMI/BILSTEIN
Old 10-12-2020, 12:44 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
For competition engines I've used Tilton starters. Somewhat expensive, but powerful- up to 2.2 KW.
Old 10-12-2020, 04:15 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
I use a Powermaster starter. Years of issue free service.
Old 10-12-2020, 07:35 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Power master since 2007
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
Old 10-12-2020, 08:01 AM
slowbird's Avatar
slowbird slowbird is offline
What compression is everyone running. That'll make a difference. Easy to spin 9:1 over vs 16:1
Old 10-12-2020, 08:06 AM
10.4:1 with Powermaster.
Old 10-12-2020, 08:33 AM
Mr Anonymous's Avatar
Mr Anonymous Mr Anonymous is offline
Ive used both Powermaster 9510, 9610 and the summit rebox "whatever" version of one of them. Only problem I had was a massive kickback on a 14:1 engine that destroyed one severely. Wasn't the starter's fault, there was an idiot between the steering wheel and the seat, looked just like me. Called PM about getting some parts. They said to just Box it up and send it in. There in the box was the main part of the starter, and in a separate bag, all of the exploded nose parts. I got a call a few days later, saying that it was some of the best destruction they'd ever seen it was pretty hilarious. They fixed me up fairly inexpensively and it was back within a few days. Like a lot of aftermarket companies, they will really take good care of you if you just reach out to them!
Clutch Guys Matter
_______________________________________
53 Studebaker, 400P/th400/9"
64 F-85
72 4-4-2 Mondello's VO Twister II
84 Hurst/Olds #2449
87 Cutlass Salon
54 Olds 88 sedan
Old 10-12-2020, 10:52 AM
12.5 to 1 with this motor. 14 to 1 with my previous one.
Old 10-12-2020, 11:17 AM
73LeMans's Avatar
73LeMans 73LeMans is offline
12.5:1 CR. To me, its both product and support that make my decision. IMI hands down. I bought one way back in 07. Shimmed is wrong and killed a gear. Called IMI on a Friday. Was at track on Saturday, and they shipped it overnight to a local address I gave them near the track. Was racing Saturday morning. And they sent more than a gear...all internals for replacing what they thought might be a bent shaft. Still have that starter in the car. I'll never forget their commitment to me.
Mark S
Who needs nice and pretty, when you can have mean and nasty?
KRE Aluminum headed 463CID 73 LeMans. Used to run 10.6x @ 124.55. 3700lbs
So much for 2020...shootin for 9s in 2021...and in 2022 apparently.....looks like 2023 as well.
>>My 73 Build thread
Old 10-14-2020, 03:16 PM
428convertib 428convertib is offline
I installed an IMI. It fixed my hot start problems, and was still running fine after five years.
Old 10-14-2020, 04:07 PM
1969GPSJ's Avatar
1969GPSJ 1969GPSJ is offline
I bought a Summit brand a couple of years ago. Car is still a project, and the starter is not mounted... I saw some mentions in the past that the unsupported nose of the mini-starter style is a problem Has anyone noticed that?
Old 10-14-2020, 04:29 PM
92GTA's Avatar
92GTA 92GTA is offline
RobbMc mini starter Gen II with the pinion support.
1969 Pontiac Firebird
