Old 08-31-2020, 04:54 PM
70KGOLD's Avatar
70KGOLD 70KGOLD is offline
Default 1964 Gto DECKLID molding clips
I have spent hours on the internet and phone tring to find the clips that attach the horizontal trim piece that goes on the deck lid on my 64. Can anyone help me locate the 8 clips Needed? Thanks
Old 08-31-2020, 08:22 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
Take one to your local parts store and match it up. they will have it in stock as body shops still use these, or similar.
That is where i got mine. Had to use ordinary nuts though.
64 Lemans hardtop
4spd, buckets
Old 08-31-2020, 08:45 PM
Cardo's Avatar
Cardo Cardo is offline
Check here. https://www.amkproducts.com/bulk-fas...forlookup=8220
"I know just enough to keep me here, but not enough to get me out"
Old 08-31-2020, 08:49 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
Have you checked with Restoration Specialties?
Old 09-01-2020, 10:55 AM
Dick Boneske's Avatar
Try this thread. The NAPA clips are the closest I've found. You have to cut the studs on the clips to make them work. AMK has the acorn nuts. I have the large-headed 8-32 Phillips head screws for the end clips if you need them.
http://forums.maxperformanceinc.com/...37#post5747437
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 09-01-2020, 06:31 PM
70KGOLD's Avatar
Anyone have the part # for these clips.
Old 09-02-2020, 12:33 PM
Look at the thread I posted. The NAPA number is mentioned several times.
BONESTOCK GOATS
Old 09-02-2020, 01:52 PM
70KGOLD's Avatar
I'm looking to find the part# for original GM clips.
Old 09-02-2020, 05:47 PM
64-3Deuces's Avatar
64-3Deuces 64-3Deuces is offline
The part number for the stud clip is 4404877 -6 required- and the part number 4848478 is for the outer threaded clips- 2 required. These were one year only clips and no longer available. And being a one year only item from what I have seen they are not repopped in OEM style. Larger clips of the same basic design can be modified and used. Check the link Dick Boneske provided and it will tell you everything you need.
