Old 08-13-2020, 06:09 PM
thepontiacman's Avatar
thepontiacman thepontiacman is online now
Default 71 Quadrajet Stamping Question
Has anyone seen a carb stamping with this in front of the number, see pic? 7041270, looks to be service replacement with date 2222.
Rochester Quadrajet.
Don't remember seeing that in front of the number before.
Let me know what you think or if you have seen this before.
thepontiacman@yahoo.com
Sent from my XT1650 using Tapatalk
Old 08-13-2020, 09:20 PM
Broken link on the picture
https://...b6489bff49.jpg/
is the web address its trying to use
Old 08-13-2020, 10:34 PM
Default pictures of carb stamping 7041270
they can be seen using Tapatalk but not on computer, so here they are again.
Technology...
Old 08-13-2020, 10:59 PM
Thats probably a 1982 produced SR
In the later 70's they went to the new numbering system where they all started with a 1 .
Looks like that one initially/accidentally got the 1 - then they caught it and bleeped it out.
Old 08-14-2020, 12:37 PM
unruhjonny's Avatar
that's a later service replacement;
The date code might lend you to believe it's 222nd day of 1972, but those "dots" only appeared with late 1970's carbs, so I'm with Baron on this one.
1970 Formula 400
Old 08-14-2020, 03:48 PM
Wonder what it might be worth, being a SR?
Old 08-14-2020, 04:08 PM
unruhjonny's Avatar
it's worth just as much as any other 7041270 SR carb;
Granted I am not in the know, but I'd guess probably an easy thousand.
I think originals are worth about double that.
1970 Formula 400
Old 08-16-2020, 09:11 AM
py71lemans py71lemans is offline
A true 7041270 should have a single ring booster in the primary. What does this have?
Old 08-16-2020, 09:23 AM
Over the years I've had two SR dated 7041270's in my hands. Both were manufactured in '74 & no longer had the single booster ring design. Neither had the same casting airhorn or throttle body as originals.
Old 08-16-2020, 03:41 PM
Kenth's Avatar
Kenth Kenth is offline
I have a 1971 400 M/T SR 7041263 made 1975 and it´s a single booster Qjet.
Why would they make a SR for the 1971 455 H.O. that is not a single booster when they obviously made one for the 400 M/T?
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 08-22-2020, 10:51 AM
Here are pics of inside carb. Looks like single booster style.
Old 08-29-2020, 08:29 AM
I have posted it for sale in the GTO parts section.
Old 09-15-2020, 04:15 PM
Here is the throttle bracket that was bolted to this carb . Looks a little different to me. What do you think?
The ball stud is usually 72-up. Other part of bracket is different from what I am used to seeing. Is it a special bracket for certain application?
Old 09-15-2020, 04:51 PM
Kenth's Avatar
This throttle lever has the bracket for 1970-72 Firebird T/A Shaker Ram Air Actuator Switch.
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 09-15-2020, 04:56 PM
blue71ta's Avatar
blue71ta blue71ta is offline
the throttle bracket is for a '71 Formula or T/A. The shaker activation switch bracket is '70 or '71 T/A. In 1972, the flapper door switch was on the gas pedal.
Old 09-15-2020, 05:19 PM
Thanks for the info!
I figured it might be something specific. I didn't remember that.
Old 09-21-2020, 12:23 PM
Carb is sold.
What is the throttle bracket/shaker activation bracket worth?
Old 09-30-2020, 10:09 AM
throttle bracket with shaker activation bracket value?
Old 10-12-2020, 06:02 PM
Brackets and carb are Sold.
Thanks for the info.
