Old 08-06-2020, 07:46 PM
TROYBOYONE's Avatar
TROYBOYONE TROYBOYONE is offline
Default Purolator Oil Filter #L30005
I am ready to change the oil in my '65 Gto Tribute, but realized I used my last oil filter on the last change. I prefer the Purolator (white) #L30005, it is an oversized alternative to the standard filter. Unfortunately none of the local parts stores carry it anymore. Does anybody have this filter that would sell a couple, or know of a possible source? Thanks in advance for any help you can provide.
Old 08-06-2020, 08:09 PM
higgenslake higgenslake is offline
Thank Advance Auto Parts. Purolator changed the color to red.
Old 08-06-2020, 09:55 PM
Sirrotica's Avatar
https://www.amazon.com/Purolator-L30...-1&tag=mh0b-20
Purolator was recently purchased by Mann filters, I suspect the ownership change may have preceded the color change to red.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 08-06-2020, 10:31 PM
TROYBOYONE's Avatar
Maybe there is an old-time parts store in someone's town that might still have some of the older L30005 filters. Any suggestions regarding such a place ?
Old 08-06-2020, 11:06 PM
Any reason you're opposed to the new red ones?
Old 08-06-2020, 11:55 PM
Sirrotica's Avatar
Nothing a $3 can of white spray paint couldn't fix.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 08-07-2020, 09:03 AM
ANDYA ANDYA is offline
WIX filters are white and are one of the best filters out there. With 4 cars I order them by the case.
Old 08-07-2020, 09:37 AM
TROYBOYONE's Avatar
According to the filter specs, the red L30005 will NOT fit my 400ci engine out of a '70 grand prix. I do know that the old white L30005 WILL fit. Maybe I am being overly cautious !
Old 08-07-2020, 09:39 AM
Sirrotica's Avatar
I have the answer to your question, TL30005. Exact same specs as the L30005, it's white, and sold on Ebay:
https://www.ebay.com/i/153706537076?...0ff4c7c8ee6a12
Amazon sells it too, for less money:
https://www.amazon.com/Purolator-TL3.../dp/B079SRGM34
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 08-07-2020, 10:17 AM
Sirrotica's Avatar
Yes, you are being overly cautious. The only difference in the filters is that GM went to the shorter filter in the mid 60s. They are completely interchangeable. Back in the day I drove a 67 326 HO Firebird and I used to buy the older long filter on the assumption that there was more filter media to filter the oil. There may be less pleats in the longer filter making both filters have the same area, I really don't know for a fact. At the time "bigger was better"............ As long as you have the physical room, you can use the older long canister filter.
When I was on COOP working at the local Pontiac dealer, while in vocational tech school (1970), the parts department would occasionally run out of one, or the other filter, as long as the canister would fit the car, we used the long filters until the parts department got some short ones.
The long filters were stocked less and less in parts store as the years went on, and most just stocked the short filter because it fit either application. The long filter is kind of a throwback, and usually has to be ordered.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 08-07-2020, 12:03 PM
John V. John V. is offline
Adding to Brad's comments, which I totally ditto.
According to Purolator website, the Tech line is aimed at the Professional trade.
From the specs, the Tech filter is same as the Red which is aimed at the D-I-Yer.
Doesn't "Tech" make it sound so much better?
Purolator actually offers a couple other oil filter models with better media, the PurolatorOne and the PurolatorBoss.
Doesn't look like they offer either in the 30005 size you want though. I started a recent thread about the use of a Fram Ultra for my '64 GTO.
I found one that fits, the Fram Ultra XG-9837, a synthetic media filter. Purolator only crosses it to their low line Red filter. But the Ultra crosses to the Wix 51522XP, which is the Wix premium line, also has synthetic media. Purolator does cross that one to their premium PurolatorBoss line as PBL25288.
These are all small can filters so if you prefer the look of the larger can, no harm in sticking with the Purolator 30005 size in the Red or the white Tech paint job. Although the Amazon prices seem pretty high for an economy filter. You might search around for better pricing, I found one source listing the TL30005 for $4.99 plus shipping. A local oil change shop that uses Purolator filters might possibly hook you up for a good price, could be worth asking around.
Old 08-10-2020, 12:58 PM
8LUG 8LUG is offline
Got 12 old style white ones left, thinner takes the red/blue ink off. and on goes the decal. Or paint them engine blue like the factory did.
Name:	oil filter #4.jpg
ID:	546832   Click image for larger version
Name:	oil filter#5.jpg
ID:	546833   Click image for larger version
Name:	oil filter #2.jpg
ID:	546834   Click image for larger version
Name:	oil filter  #1.jpg
Old 08-10-2020, 02:22 PM
Sirrotica's Avatar
I will add to the discussion here, that if you want your oil filtered to a very high standard, (roughly 8 times finer particulate removal than a standard full flow oil filter), I would recommend reading this thread that was recently posted about by pass oil filters:
https://forums.maxperformanceinc.com...72#post6162872
With a by pass oil filter your oil will stay as clean as the day you poured it into the engine. Wear on the internally oiled parts decreases dramatically, and engine life as well as oil life increases dramatically.
GM, and SAE (Society of Automotive Engineers), have both done studies that irrefutably demonstrate that oil filtered to less than 5 micron standard is a very worth while investment.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 08-10-2020, 03:18 PM
TROYBOYONE's Avatar
8LUG: If you have 12 Purolator L30005, would you consider selling me 2 of them.
I'm in Dayton Ohio.
Old 08-10-2020, 07:37 PM
Default oil filter
Found out they still make the white Purolator filter . https://www.ebay.com/itm/Engine-Oil-...97.m4902.l9144
