Old 06-06-2020, 02:41 PM
Steve C. Steve C. is offline
Default Everything You Need to Know about Valvespring Technology
Part 1, Everything You Need to Know about Valvespring Technology
https://www.hotrod.com/articles/ever...ng-technology/
In Part 2, HOT ROD Looks At How The Vast Improvements In Spring Design Affect Spring Selection, Usage, And Installation In Different Performance And Racing Venues.
https://www.hotrod.com/articles/revo...nology-part-2/
Old information here:
The Following 2 Users Say Thank You to Steve C. For This Useful Post:
Old 06-10-2020, 08:09 AM
Jay S's Avatar
Jay S Jay S is offline
Very interesting article. Thanks Steve.
I did not know Suzuki is one of the major developers for valve spring wire. A lot of development background in that article.
The section on harmonics and coil binds was very informative. Especially when they went into the conical springs.
It never occurred to me the quick car of drag week were abusing the springs twice as much as the NASCAR cup engines.
Reading the lifter paragraph you would think all our lifter failure were things of the past. The “every 4 to 5 years the lifter technology advancements double” does not seem to be making it back to most of our street machines...yet
Old 06-10-2020, 08:30 AM
AG's Avatar
AG AG is offline
I'm trying to decide which rocker ratio to use for my new motor with E heads. Based on installed height and coil bind, I measured both, I have up to 0.638" lift with a distance of 0.060" from CB. If I use a 1.6 rocker I will have 0.640" lift but I have never run that close to CB before, has anyone run that close without issue? I know it is preferable to run closer rather than further from CB for spring control, but is 0.060", or 0.058" safe?
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 06-10-2020, 08:31 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Repeating the words of my mentor spoken to me WAY back in the 1970's.
"If you ever die and go to heaven don't get reincarnated as a valve spring".....LOL.....
Old 06-10-2020, 08:48 AM
steve25 steve25 is online now
Your life might be ok if you came back in non Jr dragster go cart motor!
Old 06-10-2020, 09:54 AM
"About 0.060 inch used to be the textbook safety margin, with more OK and even desirable. That's still an acceptable standard for everyday performance use, but for cutting-edge setups the "correct" safety margin can vary up or down."
"Depending on the intended use and the spring and cam-lobe design, coil-bind safety margins can now vary from 0.015 to 0.120 inch, with tighter numbers predominating on very stiff valvetrains. Anything more than 0.150 inch may cause spring surge, which can greatly reduce the available spring load needed to close the valve."
Source:
https://www.hotrod.com/articles/how-...rance-is-safe/
Old 06-10-2020, 11:41 AM
AG's Avatar
AG AG is offline
My motor is not cutting edge race, just hot street so I guess it would be trial and error to determine if 0.060" is enough. I would hate if it was the error side and I was crunching coils and breaking or bending stuff.
Old 06-10-2020, 12:15 PM
Distance to coil bind discussion..........
https://www.speed-talk.com/forum/viewtopic.php?t=5584
Others out there....
" I always tell people that .050 away from coil bind is as tight as I would ever run a spring. I have never seen ( at least with the engines I have worked with) a spring that benefited from running it tighter than .050. Some springs like to be farther away from coil bind than others. On a Pro Stock engine they are about .120 away from coil bind. It depends on, the spring design, the camshafts lobe design, valve train weight and the amount of loft your are trying to control."
https://www.speed-talk.com/forum/viewtopic.php?t=432
Old 06-10-2020, 01:14 PM
AG's Avatar
AG AG is offline
A lot of great info in your references, I have read a lot of it before. I run between 0.080"-0.095" on my race car that goes to 6700 rpm and it doesn't skip a beat. I just want to get the maximum lift I can on my street motor so I'm not sure if I should try the 0.055"-0.060" spec with a 1.6 rocker or go with a 1.5 rocker and have more distance to CB. The springs are the smaller diameter spring package that Dave B uses from Comp with a hardened steel retainer.
Old 06-10-2020, 01:51 PM
It can be a 'complicated' subject. Another related fly in the ointment......
"We’ve experienced valve float problems created merely by adding a 1.6:1 rocker arm over a 1.5:1 ratio. This occurs because the increased ratio accelerates the valve that much faster and causes the spring to lose control."
https://www.enginelabs.com/engine-te...s-in-distress/
Cliff's comment in his post #4 brought a smile. But also very appropriate in that valve springs are among the most highly stressed components inside any engine. Doesn't really matter if cutting edge race, hot street or a "stock" type build.
