Old 03-27-2023, 04:29 PM
kpbrown31 kpbrown31 is offline
Are most of you just threading this hole in the head and then screwing in a fitting of some sort, or going back with the press in style? I tried doing a search for the 90 degree 301 fitting people mention, but haven't had any luck finding it. Pretty much only see the $30 press in one that is carried by several different vendors.
Old 03-27-2023, 05:04 PM
25stevem's Avatar
25stevem 25stevem is offline
That’s a hell of a expensive tap these days if you plan on threading that hole for a pipe plug!
I do stuff for reasons.
Old 03-27-2023, 08:32 PM
Originally Posted by 25stevem View Post
That’s a hell of an expensive tap these days if you plan on threading that hole for a pipe plug!
Yeah, true, I have nothing near that big.
Old 03-28-2023, 02:21 AM
PontiacLars PontiacLars is offline
How is this on aluminium heads? Just install threaded fitting or can one buy this unit with threads?
Old 03-28-2023, 02:35 AM
GM part #1609997
https://forums.maxperformanceinc.com...38&postcount=4
Old 03-28-2023, 03:18 AM
lust4speed's Avatar
The water jacket on an iron head is close to the area you would be threading and it would take a custom tap since the regular tap would bottom out inside the head before you had a good start on it.
Edelbrock furnishes steel pipe plugs to eliminate the heater fitting if desired, and also supplies a 1" threaded brass nipple for 5/8" hose. It is up to the end user to install a flow limiter in the nipple if desired.
Mick Batson
Old 03-28-2023, 10:41 AM
gto4evr gto4evr is offline
OPG has a version with the spring
https://www.opgi.com/cooling-heating...d-g240632.html
Old 03-28-2023, 06:21 PM
jerry455 jerry455 is offline
I bought one of these from Butler and I am going to drill out the threads on my Edelbrock heads and then tap in the fitting.
Old 03-28-2023, 06:28 PM
Tom Vaught's Avatar
Boost Engineer
If you are still going to use the heater core I would still do the restrictor mod in the feed line to the heater core. The "warm up" function of that head part still does nothing to protect the heater core if the engine sees a slug of water (due to a WOT Mode) by the engine.
Tom V.
Thread Tools
Display Modes
