Old 05-18-2020, 01:26 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Default 63 Lemans Windshield
I have the later glue in style, is the window opening the same size as the the gasket style. And does it take the same stainless trim?
Old 05-30-2020, 03:14 AM
CONCRETEHART CONCRETEHART is offline
Default windshield
I believe convertible used rubber gasket and different trim and glass dimensions
Old 05-30-2020, 11:50 AM
Doug Doug is offline
Hollander interchange book listing for 61-63 Tempest windshields:
2-dr cpe ----------2239, 2355
Spt. cpe ----------2239, 2355
S.W. ----------2239, 2355
62-63 conv-------2239
INTERCHANGE
2239--#W610 low glass
Buick Special- 61-63
Olds F85—61-63
Tempest-61-63
2355--#W623 High glass
Buick Special- S.W. & 4dr sdn
Olds F85-exc. Conv. (opt in 63)
Tempest- exc. Conv. (opt in 63)
Old 06-01-2020, 07:35 PM
c5farmer's Avatar
c5farmer c5farmer is offline
Default Same size
All openings are the same size. The glass is sized to match the installation type.
Old 06-01-2020, 10:24 PM
hobbygto65's Avatar
So if I use the smaller windshield my stainless trim won't fit, right? I called Classic city auto glass and they have had the larger one on order for awhile so I will wait and see if they get it in.
Old 06-01-2020, 10:40 PM
c5farmer's Avatar
Default Smaller windshield
The two windshields require different moldings. One uses a rubber gasket with trim used to hold the gasket and windshield in. The other uses a butyl tape and the trim is held on by clips.
