Old 04-19-2020, 09:19 PM
Cardo's Avatar
Cardo Cardo is online now
Default Core support - radiator support mounting to frame
Does anyone have a picture or pictures of the core support mounting? I know that you have washer - shims under the mount between the frame, mount, upper doughnut above the core support. What i need to know is from the bottom, is there just a large flat washer only with the bolt going through, and up top is there only a large flat washer, and a lock washer? There is a smaller washer included in my kit, and i'm trying to determine if it is used, and where. I was wondering if it possibly goes under the #3 mount because that mount bolt doesn't have a flange on it. Any original cars have a washer under the #3 mount?
"I know just enough to keep me here, but not enough to get me out"
Old 04-20-2020, 12:59 PM
NYGTO's Avatar
NYGTO NYGTO is offline
I'll get you some pictures this afternoon.
Old 04-20-2020, 01:16 PM
Cardo's Avatar
Awesome! Thank you!
Old 04-20-2020, 07:34 PM
NYGTO's Avatar
I hope the pictures are what you needed, had to send them directly because imageshack doesn't always cooperate by cell phone.
Old 04-25-2020, 03:50 PM
bbnotop bbnotop is offline
Cardo, could you post what you found out as how to put these mounts back together? Thanks in advance for any assistance.
Old 04-26-2020, 03:04 PM
Cardo's Avatar
NYGTO sent me these pictures of his original survivor car, never apart - so full credit and thanks to him for the help. The first 2 pictures are his car, and the 3rd is mine assembled. The 4th is the correct nut from the AMK catalog. I found my original nut in the giant coffee can of fasteners that came with the car, replated it and used it. The confusion came for me because all of the kits that are available, come with an incorrect nut and a lock washer. The kit of "correct" body mount hardware i purchased from Ames, does not have the correct nut, bolt or even upper mount for our cars. I used an extra lower mount rubber that i had, and cut the "stepped" ring off of it so it would fit correctly. Their upper rubber for the core support mount was much thinner.
Name:	underbody mount.jpg
ID:	538429   Click image for larger version
Name:	upper mount.jpg
ID:	538430   Click image for larger version
ID:	538431   Click image for larger version
