Old 04-01-2020, 12:14 AM
Mean Green's Avatar
Mean Green Mean Green is offline
Default Switching from stud mount to shaft rockers?
What's involved when switching from stud mount rockers to shaft rockers on an already assembled engine?
The engine currently has Harland Sharp 1.65 rockers with .250 offset and Isky lifters with .180 offset. The heads are 380 cfm High Ports.
www.lancablingsolutions.com
Old 04-01-2020, 02:10 AM
Probird's Avatar
Probird Probird is offline
You will just have to re-measure pushrod length once you get the stand height set. Probably won’t be able to use the same pushrods. That’s about it.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
Old 04-01-2020, 09:26 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
For my Crower shaft they had a tool to get the stand height correct. Then you go to measure for pushrod length, but no direction where the adjusters should be in the rocker for that. I set mine with them halfway through their adjustment to give plenty of room either way to play with lash.
Skip Fix
Old 04-01-2020, 09:44 AM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
t and d rockers are no where near half out by the directions. I was just looking at this the other day. I think its a turn and a half from all in?
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 04-01-2020, 10:04 AM
Mean Green's Avatar
I already need new pushrods, so that works out good.
I plan on getting T&D rockers. What about the offset? Does that come into play?
Old 04-01-2020, 11:31 AM
Stan Weiss's Avatar
X2
From a long time ago and I am talking 426 Hemi. You wanted the min out of the rocker. This shorted the push rod a small amount which reduced total valve train weight a small amount.
Stan
Pontiac Pump Gas List
Old 04-01-2020, 12:45 PM
Dave Polichena's Avatar
Dave Polichena Dave Polichena is offline
Be very careful when measuring geometry. I had to shave +/- .090 off my rocker pads to get that where it needed to be for my HP heads.
Dave Polichena
Old 04-01-2020, 01:48 PM
Probird's Avatar
My directions for T&D are to back the adjuster counterclockwise till the bottom of the screw is up against the rocker arm. Turn clockwise one full turn. That’s the initial setting. Don’t go more than one full turn in either direction from this setting. Otherwise it will cut off the oil supply to the rocker.
The Following User Says Thank You to Probird For This Useful Post:
Old 04-01-2020, 01:49 PM
Probird's Avatar
Yes. You need the correct offset for your heads.
Old 04-01-2020, 03:02 PM
Mean Green's Avatar
According to the T&D website you measure the center of the #1 and #3 intake valves and the center of the #1 and #3 intake pushrods, subtract, and then divide by 2. and then add .050 for pushrod clearance.
My pushrod centerline width is 3.750 inches. My intake valve centerline width is 2.850 inches. 3.750 - 2.850 = .900.
.900 divided by 2 = .450
.450 + .050 = .500
So .500 is my rocker offset? Does that sound right?
Old 04-01-2020, 03:07 PM
Mean Green's Avatar
Pics
ID:	535978   Click image for larger version
Old 04-01-2020, 05:00 PM
Dragncar Dragncar is offline
This^^^^
Old 04-01-2020, 05:16 PM
slowbird's Avatar
slowbird slowbird is offline
My hp heads needed spacers made to run t&d shafts. Goes to show you that things need checked carefully to determine what's needed.
Old 04-01-2020, 05:25 PM
GTOGEORGE's Avatar
Do you have offset lifters?
GTO George
Old 04-01-2020, 05:34 PM
Mean Green's Avatar
[QUOTE=GTOGEORGE;6125536]Do you have offset lifters?GTO George[/QUOTE
Yes, .180 offset.
Old 04-01-2020, 05:36 PM
GTOGEORGE's Avatar
[QUOTE=Mean Green;6125538]
Yes, .180 offset.
Ok.......just checking!
GTO George
Old 04-01-2020, 06:28 PM
grnmnstr's Avatar
grnmnstr grnmnstr is offline
Not something I would do on an already assembled engine. But that is just me.
1978 Pontiac Grand LeMans.......out next year
Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG
Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs.
Old 04-01-2020, 07:00 PM
Stan Weiss's Avatar
Did either of you have other than standard length valves?
Stan
Old 04-01-2020, 07:29 PM
Mark G Mark G is offline
I never thought it was worth it anything up to 1200 hp I don't see the advantage of using shaft rockers conventional rockers will work fine unless you have some really large lift camshafts but besides that waste of money just my opinion my current combo is close to 1100hp on nitrous no problems don't get me wrong they have their place
Old 04-01-2020, 07:58 PM
Stan Weiss's Avatar
Mean Green, Dave and Brian,
What do you have for over the nose valve spring pressure?
Stan
