Question about Holley 950HP Race Carb
I have a Holley 950HP that I have used on my 64 GP
with a 421. Never ran a vacuum advance, had the dist. locked out. I will be installing a 463 in the car and would like to add a vacuum advance. My question is: Can the base plate be changed to the street style version with vacuum ports? Also, should the VA be hooked to ported or full vacuum port? Thanks |
Yes it can be added to the base or use another base that has ported vacuum feature.
I have also to utilize or have activated the passage in the pass side metering block and added the needed passage in the mainbody.
Carburetor building & modification services Servicing the Pontiac community over 20 years |
Ported usually works better. As Shaker said the ports can be added but it will take some "doing"
I have a like new proform billet base plate with vacuum ports, etc I would sell. Used it for a couple years on my Holley 950HP.
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
That is the same baseplate I'm using>>I like the vacuum ports and the secondary easy to get at idle screw.
Baseplate
leeklm, sent you a PM
