Old 03-25-2020, 07:55 PM
brad cox's Avatar
brad cox brad cox is offline
Default Transmission spacer
I am trying to find a Pontiac specific spacer to put a new converter in our transmission Does anyone make one or does it have to be a custom piece?
Th400 trans BOP case
Also if anyone has one laying around they want to sell let me know!
Old 03-25-2020, 08:05 PM
Gary H's Avatar
Gary H Gary H is offline
I don't understand your question. Are you trying to put spacers between the convertor and the flexplate?
Old 03-25-2020, 08:38 PM
brad cox's Avatar
should’ve been more exact, i am looking to put a spacer between the transmission and the engine using the 6 bolts around the outside to push the trans backward
Old 03-25-2020, 08:52 PM
cgeise's Avatar
cgeise cgeise is offline
why ?????
Old 03-25-2020, 08:56 PM
brad cox's Avatar
we are trying some new converters and one of them is made for a different spacing
Old 03-25-2020, 08:59 PM
cgeise's Avatar
every gm and aftermarket converter I have ever used fit with out a spacer you sure it was seated in the tran's fully ??? unless it was a big time lock up style -- those use a spacer
Sirrotica's Avatar
If you buy an aftermarket adapter from chevy pattern to BOP, you'll have a spacer. Jegs sell them for around $50.
https://www.jegs.com/i/JEGS/555/60172/10002/-1
Not sure why you need a spacer, but you can modify it to suit your needs.
Okay I see why you need one. Jegs doesn't give a thickness spec so not sure if that works for your application. Good Luck.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 03-25-2020, 09:05 PM
brad cox's Avatar
I know it’s a very strange fitment
Unfortunately i can’t say much because it’s not mine to give the information out on but it’s a normal converter
Old 03-25-2020, 09:06 PM
brad cox's Avatar
[QUOTE=Sirrotica;6123015]If you buy an aftermarket adapter from chevy pattern to BOP, you'll have a spacer. Jegs sell them for around $50.
Thanks I’ll call and see if it’s thick enough
Old 03-25-2020, 09:24 PM
You basically need a rear engine plate?
How thick does it have to be?
Old 03-25-2020, 09:46 PM
brad cox's Avatar
Cool
Already have a mid plate in the car, Basically i am looking for something similar to this but BOP fitment
Old 03-25-2020, 09:52 PM
Just cut it out of a plate of aluminum?
How I did the midplate, just don't use all the extra width?
Trace it on a piece of aluminum and cut with jigsaw.
Half hour of work.
Old 03-25-2020, 10:00 PM
brad cox's Avatar
Half hour of work.
I’m trying to be lazy here and buy it! I will do that if i have to i was just hoping not to
Old 03-25-2020, 10:04 PM
Mark G Mark G is offline
Washers
The Following User Says Thank You to Mark G For This Useful Post:
Old 03-25-2020, 10:08 PM
cgeise's Avatar
at one time CSR made a carbon fiber tranny shield for a Pontiac application if they still do you might be able to get the steel plate that attached it to the engine.
Old 03-25-2020, 10:54 PM
John Langer's Avatar
John Langer John Langer is offline
I tried someone’s converter that was built for a 1/4” mid plate where I had an 1/8” in my car. I just spaced it out with washers. Not the smartest thing to do but it worked for what I wanted to accomplish. Now, when you space the trans back .125” you also need to move
Back your trans x-member or slot it to fit.
Old 03-25-2020, 11:41 PM
I did same worked fine..
Old 03-26-2020, 08:44 AM
taff2's Avatar
taff2 taff2 is offline
Just get a spacer plate laser cut out of steel in any thickness you want, that's how we get our BOP to Chevy trans adapter plates made. I could send you one over but the shipping will be $30-40.
Old 03-27-2020, 08:39 PM
Probird's Avatar
Probird Probird is offline
You could buy another midplate and stack it between the other midplate and the transmission.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0
2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion
and 2015 IHRA Div 5 Mod champion
Old 03-28-2020, 08:57 AM
chiefbigb chiefbigb is offline
So the ears are moved forward on this converter? If it's just the pilot normally they screw on the converter and you can change it out
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow.
