SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference. |
FS 1964,65,66,67 GTO & Lemans steel fan shroud for 17" radiator
1964 to 1967 GTO or Lemans steel radiator fan shroud for A/C or 17" radiators. I have had this for awhile now and believe it is a NOS part. It looks new and ready to install.
$295.00 plus S&H
Don Johnston DCI MOTORSPORTS LLC 330-850-5050 shop 330-628-3354 cell Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!! |
shroud
I have an original A/C car. is is a fiberglass or composite of some type, never seen a metal one?, but its cool and I know the guys out here will identify for you
That’s a ‘64 - ‘65 steel A/C shroud, the radiator upper inlet notch on the passenger side identifies it.
It could easily be modified to use the ‘66 - ‘67 radiator by simply cutting a notch on the opposite side and welding in a piece to close off the original notch, have done that myself in the past. Later years used fiberglass or plastic shrouds with the upper inlet hose notch on the drivers side. |
It is steel. Thanks for that very important info on the water outlet location. So it appears this is an NOS 64 & 65 shroud
SOLD !!!! Thank you PY
