Old 03-18-2020, 06:08 PM
Formulas Formulas is offline
Default High pressure oil pump with smaller relief ball
Anyone here try the high pressure 80 PSI oil pump with just the smaller check ball ?
If so what pressure did you end up with?
If you use the smaller ball on the 60 psi pump people usually shim the spring in attempt to get the engineered PSI back but using the smaller ball on the 80PSI might not be a bad way to go pressure wise to knock off some pressure
Kind of a in between pump pressure with the benefit of the smaller ball
Old 03-22-2020, 12:48 PM
abefromen's Avatar
abefromen abefromen is offline
Following.
May be better posted in the STREET section
