1967 GTO R-12
Does anyone still have their original compressor with the sticker showing the required amount of R-12 when recharging the system? Thanks
Yes, mine shows 4.12 lbs.
Thank you Old Goat...are you referring to the sticker?
As an aside, Ames sells reproduction stickers for the A/C compressor (see page 325 in the G35 catalogue). This doesn't help answer your question about capacity, but I just you might be interested to know that you can get a new sticker if you want one.
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
Thanks Old Goat.
No, for Tempest it’s 3.75 lbs. Full-size cars used 4.12 lbs.
thanks for that update hgerhardt
Thank You Old Goat & ZeGermanHam - Great info I didn't know and now I want to get a correct sticker for my A/C Compressor.
DAMMIT, I hate it when someone posts Wrong information on here!
I hate it even worse when it's ME! Should have made a picture to begin with, instead I just took a glance at the sticker and this is what I saw. Original compressor and sticker. Just so happens that something got dropped on it in years past and partially obliterated the Tempest quantity number! I sincerely apologize for my error!!! 3.75 is the correct amount for the Tempest. Charles |
no problem...we got the info we needed through a group effort..much appreciated
Glad we got that sorted.
Maybe a clarification is in order for future readers: if you have a modern parallel-flow condenser, you'll need considerably less refrigerant than specs show. Somewhere around 2.0 to 2.5 lbs. I learned this the hard way when I converted my '71 Chevy pickup to a PF condenser and initially overcharged it (I kept R-12). |
Hgerhardt...can you elaborate on the "parallel flow" condenser? I put a new condenser in when I completed my 67 in 2013. How do I know if it is or is not "parallel flow"? Thanks for the info.
If there are round tubes at the ends of the condenser which do a 180, then that is the original style serpentine. If there are 3/4" dia tubes arranged vertically on each end, it's a parallel-flow (PF). All modern cars use PF condensers because they're more efficient than the serpentine round-tube units.
Serpentine Condenser (orig style): Parallel-Flow: |
Thanks for the pics hgerhardt...will have to check before charging.
Subscribing... hopefully assembling mine later this year.
"I know just enough to keep me here, but not enough to get me out" |
