Old 03-14-2020, 04:59 PM
oethel's Avatar
oethel oethel is offline
Default 4l80e direct drum clearance
Just got a th400 stage 3 kit from Jakes,with 4l80e direct drum.clearance is tight at .028-.030 .th400 direct piston and backing plate in
a 4l80e direct drum.6 clutches and .077 steels,no steel wave .what is usually done to to get more clearance?
Old 03-14-2020, 07:19 PM
Half-Inch Stud's Avatar
used frictions.
TH400 piston coud be shaved.
i forget if there are thinner steels (060?) i dunno without my notebook.
Old 03-16-2020, 06:32 AM
taff2's Avatar
taff2 taff2 is offline
If you turn down the piston be careful that the bottom steel plate can't rotate under the drum lugs at the base of the drum. Using a .060" steel is the easiest way to get clearance-try Alto. You could turn .015-.020" off the top side of the pressure plate lugs.
