Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 02-25-2020, 01:48 AM
ck67goat ck67goat is offline
Default Cast 62 428 HO SR heads
Cast #62, 428 H.O. “Service Replacement” Heads:
I am the 2nd owner of these heads (not junkyard/salvage heads)
Original owner had these on his original # matching 428 H.O. (I have the PHS)
The story from orig. owner was he had problems with his factory original 1967 heads and dealer replaced with these nearly identical Cast #62 Heads (used on 68-69 428 H.O. Engines).
Uniquely, the date casting for these heads are B283 (February 28, 1973) which was nearly 4 years after last standard Cast #62 428 heads were produced.
The engine these came off supposedly ran and in all probability these do not have many miles on them (the car sat since the early 1980's), however I cannot personally attest as to whether they will bolt on and run – at least recommend a valve clean up and re-seal.
$500. Shipping options up to you, I can box up or you can pick up locally in Chicago area. I could possibly hand deliver part way if you are in the Midwest for a small fee.
67 GTO street car - 428, roller cam, TH400, GV OD, through mufflers Best ET - 11.44. Best MPH - 116
67 GP Convert 428 HO Project Car
Old 02-26-2020, 12:30 AM
GTO3DEUCES GTO3DEUCES is offline
I have #62’s on my ‘65 Goat 389...Excellent heads...
Old 02-26-2020, 04:47 PM
bradleyc309 bradleyc309 is offline
Default #62 heads
any photos
Old 02-26-2020, 10:03 PM
Originally Posted by bradleyc309 View Post
any photos
See following - let me know if you need more...
Name:	62 Heads date 2.jpg
ID:	533096   Click image for larger version
ID:	533097   Click image for larger version
Name:	62 Heads date.jpg
ID:	533098   Click image for larger version
Name:	62 Heads.jpg
Old 02-26-2020, 10:07 PM
PS - those are lead deposits on the valves which tells you these have not really run since leaded gas was common at the pump.
Old 04-13-2020, 12:46 AM
Some photos after some moderate cleaning...
ID:	537163   Click image for larger version
Name:	pair 62 heads.jpg
ID:	537164   Click image for larger version
Name:	62 Heads pair.jpg
