Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Keith Black KB Performance Pistons KB371-030+.040 455
I have a set of NEW Keith Black KB Performance Pistons KB371-030 +.040 that I had purchased for my 455 build approximately 8 years ago. They where new when purchased however, during that time I had sent them off to be ceramic coated and they have been sitting ever since. Now that I am ready to build the engine, my plans have changed for the build and have decided to add boost and stroke... so these pistons will not work.
The pics show one piston. The oil marks are just from lubing the wrist pins. I would like $399.00 for the set SHIPPED. They are $468.00 new and that's without the coatings. Sale includes Pistons, Pins and locks. You will still Need Rings. Here are the KB details of these pistons: Bore (in): 4.180 in. Bore (mm): 106.172mm Stroke: 4.210 in. Piston Style: Dish, with no valve reliefs Piston Material: Hypereutectic aluminum Compression Height (in): 1.500 in. Piston Head Volume (cc): +30.50cc Wrist Pin Style: Press-fit or floating Pin Lock Rings Included: Yes Wrist Pin Included: Yes Pin Diameter (in): 0.981 in. Piston Ring Thickness: 5/64 in. x 1/16 in. x 3/16 in. Piston Rings Included: No File Fit: No Gapless: No Quantity: Sold as a set of 8. Notes: Step dish design. Calculator Compression Calculator Tool Stroker Combinations Keith Black hypereutectic pistons are made from 390 aluminum alloy and heat-treated to T6 standards, which makes them 30 percent stronger than ordinary untreated hypereutectics. Their 100 percent CNC-machined crowns, high upper compression-ring location, gas-accumulator groove, drilled oil returns, and spiral-lock retainer grooves make these pistons outstanding for performance applications. They have a lightweight, rigid-rib skirt design that stabilizes the piston in the bore. All of this adds up to pistons that fit tighter than forged types, provide improved oil control, reduce blowby, increase ring life, eliminate cold start-up knocking, and won't cost you an arm and a leg! Thousands of models are available—find the set and options designed for your vehicle and engine application. I accept Pay Pal and can accept most major credit cards. If you have any questions or concerns please feel free to contact me. SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t" |
The pistons + Pins + retainers combined weigh 657 Grams.
SPEED SAFE, NICK
Bump
SPEED SAFE, NICK
Price dropped to 350.00 shipped.
https://www.airram.com/product.php?c...hquery=pistons SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t" Last edited by AIR RAM; 01-12-2020 at 10:43 PM. |
Still available, $350.00 + Ride
Click here for a direct link to purchase using Pay Pal or credit card. SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t" Last edited by AIR RAM; 01-18-2020 at 11:12 AM. |
Do you still have these?
** SOLD **
Thanks for looking! SPEED SAFE, NICK
