Tri-Power Tech 57-66 Tri-Power Talk
Old 12-26-2019, 03:33 PM
SD421's Avatar
SD421 SD421 is offline
Default When A Crack In The Manifold Really Matters
Hi,
How serious is having a couple of cracks where they usually appear on a 1966 tripower manifold?
When do you need to replace the manifold?
Thanks,
Don
1966 GTO
1966 421-9.3-1 comp-Race Tec 23cc Pistons
1966 Tri-Power
1967 670 Heads
Pontiac "Highlift" TriPower Cam by SpeedPro
DUR 214 Int 224 Exh @.050 - 107 ICL
LIFT .445" Int .465" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
Old 12-27-2019, 11:32 PM
Dick Boneske's Avatar
It depends on where the cracks are and how much leakage you have. They usually crack at the heat riser passage. If you have that blocked, it's a non-issue. If in the water crossover, coolant leakage would not be acceptable--but they rarely crack there.
If the cracks are in the runners, vacuum leaks will affect idle, and need to be fixed. Welding or epoxy are two options.
A used '66 intake is about $300-400. An aluminum repro costs about the same, but they have quality issues so you would need to do a careful inspection before using.
Name:	Nancy's '64 GTO, Kaukauna Car Show, '66 Tripower 025.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
The Following User Says Thank You to Dick Boneske For This Useful Post:
