Old 12-04-2019, 08:21 AM
Old Goat 67's Avatar
Default Trico Classic Wiper blade replacements 15"
Check these out guys!
Wiper blades with stainless steel inserts! Only thing not like originals is that they don’t have the Trico stamping on one end of the holders.
https://www.oreillyauto.com/detail/b...67/pontiac/gto
https://www.amazon.com/Wiper-Set-33-.../dp/B071V7FN44
Old 12-04-2019, 03:41 PM
Jeff Hamlin's Avatar
Wink Where you been
Glad you found them. They are real nice. I've been using them for over a year now.
Good fitment and they work well in the rain as they should
Old 12-13-2019, 08:35 PM
Hokie1984 Hokie1984 is offline
Also saw them on Rockauto the other day.
Old 12-13-2019, 09:59 PM
The Champ's Avatar
Back when the ACDelco warehouse distributor I used to work for (I left full time employment about 2 years ago) brought on the Trico line I worked with a Trico rep for 2 days calling on customers and showing them the advantage over other brands. This was about 5 or 6 years ago.
In working with him, we discussed all the different blades available. One that got my attention was the Trico "Classic" series blades and wiper arms. The rep told me that he would get me a complimentary set for my GTO. I was excited about this and had planned to let everyone know about this on the board. I knew they wouldn't have the "Trico" stamping on them, but I thought it would be something most here would be interested in.
However, I was disappointed when I got them as they aren't polished stainless steel like the originals.
Are they now polished stainless steel or are they still the dull finish like the one's that I have (still new in the box)?
Old 12-13-2019, 11:54 PM
Rich-Tripower's Avatar
They can't be polished per DOT regulations. Polished items can cause glare. This regulation went into effect in the late 1960's if I recall correctly.
Old 12-14-2019, 01:33 AM
60sstuff's Avatar
60sstuff 60sstuff is offline
For the Tempest Series cars.
1964, 1965 were full polished (arm, blade holder).
1966 and newer were the non-glare satin finish.
1) 1965
2) 1966
Chris.
ID:	526720   Click image for larger version
Old 12-14-2019, 03:11 PM
pfilean's Avatar
pfilean pfilean is offline
I paint the polished surface that faces the windshield flat back because of the glare. Did that on 64 GTO and still do it.
Old 12-15-2019, 09:51 AM
The Champ's Avatar
1) 1965
2) 1966
Chris.
As I have a '64, mine are polished. I guess I never paid attention on the newer one's.
That said, from your photos, the '66 units don't seem to be as "dull" as the Trico classics. Could be just how they look in the photos.
Old 12-15-2019, 10:39 AM
bob d bob d is offline
Default sun glare.
I Put electrical tape on the blades and arms on my 1965 GTO to reduce the glare so I can remove it when necessary. Thanks Bob.
Old 12-15-2019, 12:51 PM
The Champ's Avatar
FWIW - I've never had a glare problem with my polished stainless wiper arms and blades. Must be my driver position if others are having issues.
Old 12-16-2019, 10:29 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
The ones on my 65 are Tricos that have a built in wing and a red button at each end. Looks like 3 piece.
Name:	65 GTO Wiper.jpg
Skip Fix
Old 12-19-2019, 11:22 PM
ReelFun's Avatar
ReelFun ReelFun is offline
I want to slide the rubber part out and keep my arms with the wings. Will they slide out?
1965 GTO
389 Tri-Power
4-Speed
Johnny
Old 12-20-2019, 07:39 AM
The Champ's Avatar
Yes.
That's how you typically replaced blades back in the day - just replacing the rubbers.
At the very end of the blade their is a little "clip" - squeeze in and the actual rubber blade will slide out. Hard to see in this photo, but the clip is on the bottom.
Old 12-20-2019, 08:18 AM
Andre's Avatar
Andre Andre is offline
I've typically just bought the rubber replacements for my cars as I still have the original shiny stainless holders in the 64's and the 66, but I'll use the brush finished ones on my '67 as is.
Old 12-20-2019, 06:23 PM
ReelFun's Avatar
I bought some of the blades today at O'Reilys. I see they will slide out. Andre, where do you buy the rubber replacements?
1965 GTO
389 Tri-Power
4-Speed
Johnny
Old 12-21-2019, 09:11 AM
The Champ's Avatar
Any DECENT auto parts store that handles Anco or Trico should be able to get them. They may not stock them, but Anco and Trico make them.
Here's a link for Anco units for a '64 GTO on Amazon:
https://www.amazon.com/s?i=automotiv...dp_lf_ladp_1_4
Old 12-21-2019, 10:11 AM
Skip Fix's Avatar
Problem with mine is one side is missing one end where the red button is.
Skip Fix
Old 12-21-2019, 09:40 PM
Lemans64's Avatar
Lemans64 Lemans64 is offline
I bought my GM replacements for GM, LOL. Ya I know they are probably not available anymore. Just the rubber parts for my stock shiny stainless metal blades. Can supply the part number if anybody wants but I'm pretty sure they are no longer available.
64 Lemans hardtop
4spd, buckets
Old 12-22-2019, 01:47 PM
Skip Fix's Avatar
So where the winged ones factory or just a replacement?
My '04 GTO the factory arms had a wing on the driver's side.
Skip Fix
Old 12-27-2019, 11:31 PM
ReelFun's Avatar
My winged arms are stamped Anco. I doubt they are factory. Most likely replaced over the years. They were on the car when I got it 12 years ago.
1965 GTO
389 Tri-Power
4-Speed
Johnny
