Nitrous Install Questions
Looking to install a Nitrous puck system in my 73 bird. I have never have used nitrous before so I am looking for any tips , tricks info. I am running the puck system as it will fit under my formula hood. No real reason to hide it. looking for about 200 hp. Solid bottom end with aluminum heads and about 10.3 compression. Watched several videos and have the general information. Working on the fuel system now but will is mostly in place. 1/2 line from the tank to the carb with a RobbMC 1100hp mechanical pump. Just need to get the regulator set correctly.
1. So spark splug type and what to drop the plug down to as far a heat range 2. Safety minimum requirements... 3. Will try to tie this into my MSD6AL-2 programmable box-researching that now. Please feel free to express your thoughts...also on launching. For me typically with drag radials I can get out clean..currently the car ran a best of 11.9 street shape.
1973 Firebird Formula 1969 Firebird Convertible |
What is a puck system?
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
Your 6al-2 programmable box will do what you need... there is PC based software for programming it for nitrous retard...
What type of fuel system do you have? |
A 200 hit doesn't require many changes... that pump is plenty for what you're after... I ran a 200 hit on a 400 with a holly electric pump at the tank..... it fueled the engine and nitrous system. |
Do you have to purge a plate system?
no you dont have to purge. purging can adjust the bottle pressure and it eliminates any air in the line before you use it
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
What plugs are folks running for your setup? type and range?
You could use a Ngk R5671-8 or -9 plug.
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046 jet First ultra street/ultimate street NOS car to get into the 4's! 1.079 4.559 153.23. 3100 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! T2TTFMF! Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
