Joining the 10.5 club!!
I did not think it would happen this year, but had a great day at the track today with Darby, who kept pointing me in the right direction until I made the final round and had my best ET ever while finishing 2nd place!
Thank you Darby and others here on the forum for your assistance and advice!
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
At 128 nice
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
Congratulations!
Congrats on the 10.50 Club!
Darby's a good teacher.
Congrats!!!!
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
Awesome job! Welcome to the club!
My inspiration for this build came from members like TA Man, Firechicken, and of course Darby, who's 9.xx car sounds like grandma going to church on Sunday.
I get a kick out of running up against cars that look and sound like all-out drag machines, and silently crossing the line in front of them, or hanging right on their tail when heads up. When Darby and I run together, spectators can remove their earplugs and carry on a conversation! Several people were convinced I had a pro charger, as they could hear a little gear whine from the TH400 low gear set. Here is a short clip... the slower car in the far lane sounds like a monster coming down the track, meanwhile you barely hear the Pontiac coming up from the rear. Good times https://youtu.be/zm51XLofOp8 Sent from my SM-G965U using Tapatalk
Very exciting to get that far into the 10s with your combo. How did you get the car so light?
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
Congrats Lee!, That's A really nice combo u have put together, and you keep tweaking here and there it will run into the 30's or better on a set of radials! I better get my ass tuning or you'll catch me lol
Congrads! I've probably asked before but what convertor?
Continental 10" "Jim Hand special".
Nothing too special regarding reduced car weight. Smith race craft control arms, 28lb lawn mower battery, a few rust holes in the rear qtrs, manual steering and disc brakes, aluminum front calipers and wilwood MC up front, ford explorer style disc brakes on the 9". Weld drag wheels. Otherwise full sheet metal and glass. For the most recent runs I removed the passenger seat, back seat, and wiper motor. I will run it on the truck scale to get an accurate number and post. In addition, I am 160 lbs so that helps Sent from my SM-G965U using Tapatalk
Good job! Trying to get there myself.
[QUOTE=leeklm;6076315]Continental 10" "Jim Hand special".
Nice!
Ran it over the truck scale "as run" at the track. Add my skinny 160LB butt to it and comes out to 3,320 lbs.
Awesome combo.
What rear tire? |
28 x 9.5" Hoosier bias slick
Are you running a 2.75 first gear? |
Great job! You cant go wrong listening to Darby...
I remember when I went 11.20' from 12.20's after a change... I was ecstatic! You're screwed now..lol you are gonna chase better e.t.s like a drug! |
Correct
Congrats Lee! Great numbers for such a mild combo!
Greg Weigart IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/6.21@110.47/9.77@137.08 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 |
