Strange Method For Oil Galley Plug Retention
First time I have seen this method for retaining the front press in oil galley plugs. Now if they had only put the piston/rod assemblies in the correct bank and lined up the timing marks on the timing gears properly they probably would have had a decent running engine.
Looks like they tried peening them in with a railroad spike then went full on Larry the cable guy on it.
I like the lettered rods, I guess they were dyslexic though
I bet that ran great with a couple bottles of octane boost 😎
'71 GTO, 406 CID, 60916, 1.65 HS, '69 #46 Heads 230CFM, 800CFM Q-jet, TH400, 12 Bolt 3.55 '72 Lemans, Lucerne Blue, WU2, T41, L78, M22, G80 |
Bwaahaahaaaa
Frank M. 75 Firebird 68 Firebird 400 RAIII 66 Chevy II 461 Pontiac in AZ |
It was prolly running on 1/2 gal plastic bottles of Bourbon before that.
Limited edition RA/CC = RAM AIR/COTTON CANDY...……….
It's known to be worth at least $.50 over any other similar Stratostreak V8.... |
The worst thing is that it’s pink!
Wow.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
They drilled the block for a aluminum rivet ?? A little JB weld and staking the plug will do it.
Besides, this guy needs his Pontiac card pulled for the paint job. |
What makes you think he has a card LOL.
"I don't need no stinking card" Maybe it was a Mary Kay car in a previous life
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express 2024 Cadillac LYRIQ |
Does it have RRE stamped on it anywhere? Could be a Bruce Fulper engine. He is an expert Pontiac engine rebuilder after all.
Might have worked if he had used silver (1964 or earlier) quarters.
My Pontiac is a '57 GMC with its original 347" Pontiac V8 and dual-range Hydra-Matic. |
Lol
72 lemans,455 e-head, UD 255/263 solid flat,3.73 gears,,,10" 4400 converter,, 6.68 at 101.8 mph,,1.44 60 ft.2007 (cam 271/278 roller)9"CC.4.11gear 6.41 at 106.32 mph 1.42 60 ft.(2009) SOLD,SOLD 1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86' |
Maybe it's Richard Simmons car???
Close to the pink that was on a TA at Norwalk a few years ago.
Definitely not a nickel and dime build.
Triple Black 1971 GTO |
Holy crap!
Well if your ever short for Change at a Toll both you can always pull your timing cover!
I'm speechless. How can one justify that?
I guess it's what's to be expected for someone who paints a Pontiac engine that color. .
Seems it would be a PITA to do it that way versus tapping the holes or driving in/staking a plug. What does it look like under the coins?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
