Old 09-06-2019, 02:46 PM
chiphead's Avatar
chiphead chiphead is offline
Default Octane requirements for nitrous and high SCR?
New build is a 434 with ported 670 iron heads at 9.8:1 compression. Lunati 231/239/110 on 104.5 ICL. With an intake valve closing of 65.5* ABDC, the DCR should be about 7.8:1.
What octane fuel should be used with a 150 shot of nitrous? Single stage plate under a Q-jet on RPM intake.
Old 09-07-2019, 10:30 AM
chiphead's Avatar
Hmm, I sense some hesitation to answer this one. So let me ask another way: Can I run a 150 shot on 93 octane pump gas, or do I need straight VP110 LL?
OR, am I limited to a 100 HP shot on pump gas?
Assume engine is sealed up well and tuned properly.
Old 09-07-2019, 11:54 AM
firechicken's Avatar
firechicken firechicken is offline
If it may help,
I ran a 9.5:1 412 250cfm 6X head with 230/236 110 ls installed at 106 hf cam on 92 octane. 150 shot and pulled 4 deg. Of timing without issue.
Old 09-07-2019, 04:10 PM
charlie66's Avatar
I have a 461ci 11.3 to 1 pump gas (93 octane) motor with a 150 shot . But i have a separate fuel pump and cell with 108 that mixes with the 93 for the NOS. Works great.. Never tried it with straight 93. Id be skeptical just like you.
My Half AN Injun.....
Old 09-15-2019, 10:35 PM
blueghoast's Avatar
I ran a 462 with 9.5 comp. and a 275 shot on 92 octane with 8* out and
no problems, I was using a separate pump just for the nitras.
I've always run two pumps on my car for nitras. and always pulled 8*
and haven't had a problem yet. Hope this helps.
GT.
Old 09-15-2019, 10:37 PM
blueghoast's Avatar
I've run more comp. with this combo too.
GT.
Old 09-16-2019, 03:36 PM
chiphead's Avatar
Blueghost, How big a cam were you running? Do you know the adv duration and LSA? Trying to compare intake closing event to what I have.
Old 09-17-2019, 11:37 PM
blueghoast's Avatar
There were deferent ones. I'll get the cam cards out tomorrow and let ya know.
GT.
Old 11-22-2019, 01:12 AM
blueghoast's Avatar
Man I had forgot all about this.
I'll be in my garage tomorrow and get some of this info for ya, Sorry bout dat.
GT.
Old 12-03-2019, 11:59 PM
blueghoast's Avatar
Sorry I will get it eventually for you.
GT.
Old 12-05-2019, 03:45 AM
Brian Baker's Avatar
FWIW, my old Discomobile was pushing 11.5:1 CR with iron heads and I ran VP C-16 racing gas in it, spraying up to a 250-HP shot. No issues
Old 12-05-2019, 02:00 PM
chiphead's Avatar
Good info guys, keep it coming.
