Old 08-29-2019, 08:03 AM
ScottU's Avatar
ScottU ScottU is offline
Default Number 4 Rod bearing
Had number 4 rod bearing fail. All other rod and main bearings look like new, even number 3. Engine is a year old with roughly 80 passes. All lifters look like new as well.
Any suggestions on where to look. Oil pressure and clearances are in check.
Old 08-29-2019, 08:07 AM
charlie66's Avatar
get the rod checked...
My Half AN Injun.....
Old 08-29-2019, 09:18 AM
ScottU's Avatar
https://lh3.googleusercontent.com/_O...0agyKwfKN3qaBQ
Old 08-29-2019, 09:45 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
I would have that rod checked for size. It may be too tight.
Old 08-29-2019, 02:54 PM
mgarblik mgarblik is offline
A few pics would be helpful. What I would like to see is the bearings and also a pic or two of the rod big end looking at where the bearing sits.
Old 08-29-2019, 10:26 PM
Elarson's Avatar
Elarson Elarson is offline
Any signs of detonation in that cylinder? That will pound the snot out of a rod bearing.
Is the bearing cracked and spalled (fatigue), wiped (ran dry), blackened (not enough oil to keep it cool)? Other?
Eric
Old 08-29-2019, 11:39 PM
Dragncar Dragncar is offline
Are you main bearing the Clevite style ? If they are they need drilled to match the hole coming from the tab side of the block. Race bearings have a slot and do not need this.
Whittmore told me I would loose either # 4 or #6 rd bearing if I did not do it.
Old 08-30-2019, 03:08 PM
ScottU's Avatar
Clevite Chev rod bearing with 3/4 groove FM main bearings
Old 08-30-2019, 03:23 PM
ScottU's Avatar
[ATTACH][ATTACH][ATTACH]Click image for larger version
Old 08-30-2019, 04:06 PM
Mike Davis's Avatar
Are you positive the upper and lower halves were in the right orientation? looks like the one in the second picture is hanging over into where the radius of the crank is.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 08-30-2019, 08:00 PM
The piston pictured looks completely different from the one on either side. Did you clean the piston head in that cylinder? If not, something was going on in that cylinder. If ring lands are pinched and oil has made it's way to the top, detonation follows quickly and kills the bearing. However, looking at the bearing, it looks like oil starvation, so not sure without some more info and pics. Don't want to guess. Could you post a few pics of some of the other rod bearings for comparison? Thanks
Old 09-03-2019, 07:53 AM
ScottU's Avatar
The top of #4 piston is cleaner than the rest. The picture shows what it looked liked when the head was removed. The #4 combustion chamber is cleaner that the rest as well. The center face of the intake valve is bare and clean about the size of a dime and the machined pocket in the head is bare and clean as well adjacent the intake valve.
I am leaning toward a ring problem in that one cylinder that may have caused the rod bearing to go.
Bearings were put in correctly.
Old 09-03-2019, 08:23 AM
charlie66's Avatar
Was water getting in there. Check the cylinder wall for a crack or head gasket for a leak.. maybe check the head for a crack as well...
Old 09-03-2019, 08:37 AM
PAUL K's Avatar
PAUL K PAUL K is offline
X 2 also pressure test the head. Water will clean up the piston like yours is and wipe out the bearing.
Go fast, see Elvis!
Old 09-03-2019, 10:02 AM
ScottU's Avatar
Will do, that makes the most sense.
Old 09-03-2019, 10:22 AM
I think the piston is clean because the bearing was wearing out making the piston hitting the head. (or very close)
I'd check the crank holes and block holes for obstruction?
What was the clearances on rod bearings?
Also were the bearings for big chamfer on crank?
Old 09-03-2019, 10:42 AM
Try this link:
Bearing Analysis
Looks about like the first one, Hot Short.
Old 09-03-2019, 10:48 AM
ScottU's Avatar
You may be right, but I would think there would be combustion deposits from before. Have 0.036 deck clearance. Pistons are at zero deck with a 0.036 head gasket. Pistons are flat tops. Rods 0.0025.
Engine ran fine on the dyno and for about 80 passes afterwards. Then slowed down all of a sudden. I have a System One oil filter which I take apart on a regular basis. Did not show any debris until the last weekend out. Car was fine on Saturday and first two passes on Sunday then slowed 0.06 on the next pass then slowed up again the next pass. I then parked it to determine the cause. Pulled the filter apart and found debris, which lead to taking the engine apart.
Going to go through it all before putting it back together.
Old 09-03-2019, 11:53 AM
What block do you have?
Did oil pressure drop on run?
Possibly block cracked from main to cam bore (along oil passage) if stock block?
Old 09-03-2019, 11:58 AM
ScottU's Avatar
MR-1 block.
Did not notice oil pressure drop, however I do not have a data logger. I do run an accumulator.
