Old 08-07-2019, 10:27 AM
BN's Avatar
BN BN is offline
Default Hidden radio antenna
1970 GTO convertible, I have an original AM/FM stereo that doesn't get good reception. It looks like the small wires that come from the windshield antenna are in bad shape. I'd rather not replace an otherwise good windshield just to get a new antenna. Does anyone know of any hidden antennas that would work? I want to keep stock appearance.
Old 08-08-2019, 03:23 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Almost 50 years ago I bought a self-stick inside-windshield antenna (J.C.Whitney?).
Old 08-08-2019, 08:38 AM
HWYSTR455's Avatar
If the windshield is more than 10 years old, it's not a 'good' windshield. It most likely has all kinds of spidering on it at night when oncoming cars' lights hit it. Once you replace it, you will go 'oh wow!', betcha a million.
But, to further diag this, where is the wire look like it's in 'bad shape' ? Where it exits the glass where the plug is? Maybe post a pic.
You may want to check the piece that bolts to the cowl, that the antenna plugs into. Make sure the connection is clean, and is not damaged in any way.
That part has an inside piece as well, the antenna 'cord' that goes to the back of the radio. Those get beat up over time, and replacing that may be all you need. Not always fun to replace, but it would eliminate that as a possible cause, and is inexpensive.
Finally, it could be the internals of the radio itself. If it's an OE one, and you want it to work, you could send it off to be restored, but that's not inexpensive, and even when done, it will still just be a 50 yo OE radio.
EDIT: Also check for the ground strap on the cowl that makes contact with the hood when closed. That actually acts kind of like an antenna too.
Old 08-08-2019, 08:51 AM
1969GiPper 1969GiPper is offline
Is the reception poor on both AM and FM stations? If you’re getting no reception on AM stations and poor or weak reception on FM stations then you may just have an antenna connection problem (not plugged in).
Old 08-08-2019, 12:14 PM
BN's Avatar
BN BN is offline
Radio was restored by a member of the forums. I took the cowl molding off and verified that everything was plugged in. The reason I think it's the windshield wires, is they were bare and frayed. I put some liquid electrical tape on them to cover the exposed wire, so a picture wouldn't show much. No reception whatsoever on AM.
Old 08-09-2019, 01:04 PM
HWYSTR455's Avatar
How old is the windshield?
Old 08-09-2019, 04:48 PM
BN's Avatar
BN BN is offline
Not sure. I've only had the car three years, and it was in it when I bought it.
Old 03-07-2022, 10:44 PM
4dblnkldude's Avatar
[QUOTE=HWYSTR455;6049156]If the windshield is more than 10 years old, it's not a 'good' windshield. It most likely has all kinds of spidering on it at night when oncoming cars' lights hit it. Once you replace it, you will go 'oh wow!', betcha a million.
Reviving old thread... having this issue now. Where is the plug exactly?
Old 03-08-2022, 07:47 AM
HWYSTR455's Avatar
It's in the cowl, remove the plastic grate for the wiper trans, you will see it.
Old 07-01-2023, 06:06 PM
BN's Avatar
BN BN is offline
Forgot about this thread….started a new one in this section. Anyway, replaced the windshield, plugged in…terrible reception. Replaced that thing that goes from cowl to radio…still terrible. Ideas?
Old 07-01-2023, 11:51 PM
this may help:
https://www.rockauto.com/en/moreinfo...&pt=99&jsn=478
cheap - if it works you know what the issue is.
Old 07-02-2023, 01:58 AM
unruhjonny's Avatar
i have found a radio antenna on amazon that you could plug into your radio, and set along the top of the dash to verify if this is your issue.
1970 Formula 400
Old 07-02-2023, 09:32 AM
HWYSTR455's Avatar
It's the radio, but you still haven't mentioned your cowl to hood ground strap. It's a U shaped flat piece of sprung metal with teeth on it, should be in the center of the hood.
If that's there, then it's the radio which is the problem.
As I've stated many times, you can't expect 'performance' sound from an OE radio of that vintage.
'Works', and 'works great', are a matter of opinion.
Old 07-02-2023, 11:14 AM
unruhjonny's Avatar
please humour this;
are you sure it’s the radio or antenna that’s the culprit?
if the sound quality is bad, could it not possibly be the speakers?
I ran for the last couple years of driving my Firebird (before taking it off the road) a 1970 AM/FM radio in my car;
I had good speakers;
I had a radio guy look at it the radio before using it - all he needed to do when hooking it to his bench testing setup was to fine tune it a smidge.
I also had a trunk mounted six(?) disc cd player in the trunk - this played through an FM modulator(?);
radio stations sounded fine, and so did my cd player (it was all playing straight through the radio).
1970 Formula 400
Old 07-02-2023, 05:11 PM
BN's Avatar
BN BN is offline
The ground piece is there. Also, the 8 Track player sounds great, so I know it's not the speaker. Radio can't pull in one fm station and I live in an area with a ton of stations. Think I'm gonna try hooking up a cheapie antenna to rule out antenna, but leaning toward it's the radio.
The Following User Says Thank You to BN For This Useful Post:
