Old 05-14-2019, 03:16 PM
Jim Perez Jim Perez is offline
Default Part numbers for 1969 4sp shifter assembly?
Hi all,
I'm getting confused with what parts I need for my 69 Judge. I just would like to be sure I'm buying the right parts (original numbers, i have aftermarket now) if single items or complete assembly. I see shifter handles and shifter bases? on ebay. what should those numbers be? I see I can get reproduction linkage from inline tube. At a recent Auto swap meet I saw a shifter handle, pretty sure correct, but bolted to aftermarket base. Just need to know exactly what to look for.
Thanks,
Jim
Old 05-14-2019, 04:13 PM
unruhjonny's Avatar
unruhjonny unruhjonny is online now
I am replying here, because I have back issues of High Performance Pontiac back at home;
Several years ago HPP did a Hurst shifter article that was over two issues;
I do not know if the shifter body part number is listed, but I am confident that the shifter stick number is listed.
1970 Formula 400
Old 05-14-2019, 04:29 PM
gto4evr gto4evr is offline
I've got a date coded shifter sitting at home I can look at with the numbers. I went through all this a few years ago scraping together everything. One thing to be aware of if you're starting from scratch, the back lock linkage and hardware is definitely different for 69. The "69-72" parts that Ames/inline sell are 70-72 design. it fits on 69 but it's different. I was missing the pivot bolt and ended up having to make one because they're hens teeth. I made a couple at the time and might still have an extra I didn't sell, but unless you've got a 69 back lock to match with it, you won't need it if you end up with the repop 70-72 style.
Old 05-14-2019, 05:23 PM
BOB VIDAN BOB VIDAN is offline
5324 is the 68/9 bucket seat handle number. IIRC you have to pull the handle from the body to see it.
Practicing social distancing for 65+ years
Old 05-14-2019, 08:28 PM
yep, the chrome hurst handle is a 5324, stamped on the bottom of the arm where it snaps into the shifter.
Shifter assembly body number is 3138 and there's a date code up the side of it if you're really worried about numbers.
Note the back lock linkage and pivot bolt, different than the pictures of the repops which are based on the 70-72 design. you can't mix hardware, if you use the 70-72 linkage then you must use the 70-72 pivot bolt.
original virgin shifters have the embossed rubber molded into the ends of the levers. Most were ripped out and replaced with the hurst insert bushings to clean the sloppiness out of the setup. problem is you need to drill the holes open for the bushings so there's no going back. I'm on the fence about mine, these are still there and not ripped up so I'll cross the bridge once I get this all together and see how sloppy it feels.
ID:	512261   Click image for larger version
ID:	512262   Click image for larger version
ID:	512263   Click image for larger version
ID:	512264   Click image for larger version
Old 05-14-2019, 08:35 PM
the repop back lock
Old 05-14-2019, 09:15 PM
tom s tom s is offline
Glad you still have it!Tom
Old 05-15-2019, 11:13 AM
4zpeed's Avatar
4zpeed 4zpeed is offline
Originally Posted by Jim Perez View Post
Hi all,
Thanks,
Jim
Hi Jim here is a link to David's 4 Speeds, they have the complete assembly you are looking for.
Very nice car by the way, good luck! https://www.yelp.com/biz/davids-4-speeds-milwaukee-2
Frank
Poncho Huggen, Gear Snatchen, Posi Piro.
Old 05-15-2019, 11:28 AM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default 1969 GTO Hurst factory 4 speed shifter; Muncie transmission
Muncie 4 speed: 1969 Pontiac A body cars, some of the steering column lock out parts are one year only parts. Specifically the long stud (which holds the 3-4 lever in place and the pivot for the steering column lockout which goes on top of that stud).
ID:	512298   Click image for larger version
ID:	512299   Click image for larger version
ID:	512300   Click image for larger version
Peter Serio
Owner, Precision Pontiac
Old 06-05-2019, 01:29 PM
notime's Avatar
notime notime is offline
I have everything if you need it. 1 year only unrestored from a western car
WWW.SUPERCARCREATIONS.COM
Old 06-09-2019, 11:25 PM
Thanks Tom,
Enjoying it as much as I can.
Jim
Old 06-09-2019, 11:27 PM
Hi,
Thanks for offering, any pics?
Price?
Not sure of rules, if this needs to be switched to buy/sell, sorry.
Jim
Old 06-09-2019, 11:28 PM
Thank you all for your time and info.
Jim
