hi i have the opportunity to buy one of two tranys for my 65 manual conversion. i was wondering if you guys could help me identify and chose one of the two.
https://www.flickr.com/photos/148214090@N06/ the first 3 pics are of 1...it is 50 bucks the second 3 pics are of the other and its is a 100 buck. thank you in advanced guys. |
65 chevy 1/2 ton pick up ??
I see 2 tired 3 speeds ..1 with a funky pos lever thats upside down no thank you just my opinion |
i dont really have money for a muncie or a 4 speed nor is there any aroud my area. would this be suitable until i can afford a 4 speed?
If the car is running now with an automatic, leave it in and wait till you have the cash for a proper tranny. Spending money and time on those in the photos is likely a waste. Who knows what's inside them.
1965 Pontiac GTO 455/469 w/ #48 Heads, '65 Tri-Power 9.25:1 CR Stump Puller Cam Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00 3.55 Rear Differential Front: 225/60R15 Height: 25.6" Rear: 275/60R15 Height: 28" |
i know nothing about those transmissions, but i would not be surprised to see a tractor motor pontiac stick car run faster with a three speed than a four. one less shift and these engines don't give up like a 350 chevy if they take a big rpm hit on a shift.
as for your idea to complete the conversion with a cheap 3 speed now and get a four speed later, i see nothing wrong with that idea either, except you might want to think about the input/output spline counts. |
Why do you say tractor motor? I took the 6 cylinder out lol.
Well thanks for the advice on the spline count didn't even think about that. As for what's in them I seen they sell rebuild kits for like 50-70$ i have never done a Pontiac trans but im sure I could figure it out and have the tools to do it at work. Thank you guys for your opinions and advice.... |
Looks like a 70s Chevy truck three speed. It would bolt in but the only available shifter would be up to the dash. Also the “peanut” 3 speed that came behind 6 cylinders cannot be rebuilt at any cost because the parts simply aren’t available
If you can't afford the 4 speed why not look for a heavy duty Ford 3 speed that were used in 65.
