12 bolt carrier rear end identification help please.
Hello, first let me thank you all for the amazing help you have been with my 65 build.
Anyways need help identifying a 12 bolt passenger car rear end i came across for 5 bucks at an auction. I only have the carrier part so no axle tube number or anything like that. i will post pictures here shortly. pinion gear numbers: 02253 I counted teeth and got 35 ring teeth and 6 pinion 5831 ring gear number: 92810 583 1-6 47FURMATFX 419 case number from what i can make out at least 826241 or 826247 and 72 or 12 also the u joint cap bolts on through the side instead of straight on like normal. |
Please measure the diameter of the ring gear and report back?
I don't recall GM making a gear set with that ratio. Sounds like it could be a Ford R&P.
1979 Trans Am WS-6 .030 455 zero decked flat pistons 96 heads with SS valves 041 cam with Rhoads lifters 1.65 rockers RPM rods 800 Cliffs Q Jet on Holley Street Dominator ST-10 4 speed (3.42 first) w 2.73 rear gear __________________________________________________ _______________________________ 469th TFS Korat Thailand 1968-69 F-4E Muzzle 2 |
Ok I measured the ring gear and got 9 1/2 am going to post pictures in a second
Who told you that was a 12 bolt passenger rear?
Couldn't be further from the truth Should of kept your 5 bux
If your not at the table you're on the menu A man who falls for everything stands for nothing. |
so what is it?
Something other than what we're used to dealing with. Math says ratio is 5.83, maybe a tractor?
Yup, no GM 12 bolt there!
I guess for scrap metal it's worth 5 bucks.
