Brake stuff !!!
Hi everyone
I am in the process of tidying up my 1970 Firebird, and renewing what I am not happy with or what I think is not right. My brakes is the big issue for me. They work fine but I know they are not correct for the car, the booster and master cylinder. This is what I have I am looking at replacing it with one ----> Brake Booster Has anybody on here used these Also, down on my subframe I have this and a Brake Line Lock lever Would buying the Booster above mean that this can be removed. Thanks Guys for any help Always appreciate it Mick Last edited by Mickey_London; 03-27-2019 at 05:20 AM. |
Wow, you're right, someone completely changed your system.
A bit of a bodger I think
These exhaust hangers are what was used for the radiator core support bushings Anyway, slowly getting the old girl back to her former glory Mick |
The link you posted is for a 1971 style and newer master cylinder and booster setup.
Pontiac changed from the 3 valve set up in 1970 to a 1 valve setup in 1971 . Simpler and easier and probably cheaper as well. If you are not super anal about originality, that 1971 set would be a lot closer to a factory set up than what you have right now. You can also get any new brake lines you need from that same supplier to make your installation go smoother. I don’t see any reason you would have to keep that other valve you posted a picture of. The 1971 setup should work well for you. BTW, are you disc brakes on the front and drums on the rear? Sent from my iPhone using Tapatalk
...Steve T. "Resurrection of a 1970 Trans Am" Blog www.455hota.wordpress.com ------------------------------------- 1966 GTO 4 speed Hardtop Alabama car (Marina Turquoise w turquoise interior) 1970 TA 4 speed Canadian car (Lucerne Blue w bright blue interior) |
Thanks for the reply 455hota
It is not going to be a Concours Car but would like it to look better then it is, so the eBay link would do me fine Yes, I have discs at the front and drums at the rear Much appreciated Mick |
Then I would install the simplified 1971 setup for sure. It will look much more correct and than what you currently have.
In keeping with close to original OEM styling on my second gen TA a few years back, I had a good outcome with Right Stuff for everything from calipers, drums, pre-bent lines and etc.
Thank you for the advise Guys
I will have a look at the Right Stuff web site Mick |
Just thinking out loud here but......
If I get the Booster from the eBay link above does it then mean I can get rid of that valve thingy in the previous photo and also this The Red line comes in from the Master Cylinder The Green goes off to the passanger side front brake The Blue goes to the drivers side front brake Thanks again for any help Mick |
https://www.jegs.com/i/Right-Stuff/9...70171/10002/-1 76TA462 is right. Since originality is no big deal, for $254.00 USD + shipping and international import fee, you can order just what you need from JEG's here in the US. That includes vacuum booster, master cylinder & proportioning valve already tubed up. All you do is install it and run new brake lines out to all four wheels. Bleed your brakes and your done.
Ol' man Smith Pigeon Forge, Tn. Grand Rod Run Spring 2012 https://www.youtube.com/watch?v=DUIuGvWWthA http://s223.photobucket.com/user/fas...d%20Run%202012 Son video'd this... http://s223.photobucket.com/user/fas...a.mp4.html?o=0 |
Hello Mickey,
There is also one for about $40.00 less @ $216.00 USD. Same as above except no Delco stamp on the booster. No big deal if originality doesn't matter. They both look good. See link below. https://www.jegs.com/i/Right+Stuff/9...yABEgK7ePD_BwE
Morning All
Again, thanks to all, taking their time out to try to help. I ordered the one on eBay on the 27th. I have looked at the ones on JEGS but it works out cheaper for me with eBay and their International Shipping Program. Normally takes around 2 weeks to get here, but that is no biggy for me. Now just debating whether to buy the preshaped lines or just make them up myself haha When I receive the Booster I will post it up here if anyone is interested Mick :-) Last edited by Mickey_London; 03-29-2019 at 03:35 AM. Reason: Spelling Mistakes Because Of My Fat Fingers |
Thread Tools | |
Display Modes | |
