Old 01-30-2019, 05:21 PM
bb400ho bb400ho is offline
Default WTB power window set up 66-67 post
looking for a complete power window set up for a 67 post
let me know if you can help
thanks Bryan
Old 02-01-2019, 01:04 PM
i4abuygto's Avatar
i4abuygto i4abuygto is offline
I have a complete set for a 67 GTO convertible that I likely will not be using. The rear regulators may be different with hard top / post.
It was taken off a 67 Lemans Convertible many years ago and has been in heated storage. It is complete including the relay and all wiring. Some of the wires that go thru the driver door jam have the wires exposed and need to be repaired with heat shrink / splice. All has been bench tested and works.
Name:	67 Conv. Power Windows.JPG
ID:	504460   Click image for larger version
Name:	67 relay switches.jpg
ID:	504461   Click image for larger version
Name:	Power windows 3.JPG
ID:	504462   Click image for larger version
ID:	504463   Click image for larger version
Name:	67 Passenger Door Reg.JPG
Old 02-01-2019, 06:08 PM
Default power windows
i was told that the rear regulators are different for the post.not sure maybe i could modify? how much are you asking for the setup?
thanks Bryan
Old 02-07-2019, 04:33 PM
bump i4abuygto, what are you asking for your setup?
thanks Bryan
Old 02-19-2019, 08:36 PM
tri.lllgto tri.lllgto is offline
Default 66/67 post pwr windows
Digging for the LH regulator for hdtp, I believe I turned up a post sedan set. Will do somemore digging, but I believe I have what you're looking for.
Old 03-06-2019, 09:16 AM
Your power windows are ready to be shipped.
