Hey guys,
I stumbled across this old Ultradyne camshaft that is in usable shape. I have found a number stamped on the back. The number is 37947. I assume this is the part number. Do you all have any idea what the specs are for this camshaft? I have also posted in the race section. |
I have several Ultradyne catalogs. The number you posted is not enough. Typically Ultradyne cams would hand engrave lots of important information either on the front of the cam #1 bearing journal as you face it. or across the back of the #5 bearing journal. Typically it would say UD for Ultradyne, then the duration, then the LSA would also be listed. Sometimes they would list the lift, but generally not. As I said, I have a master catalog of everything they made up to the time of Harold Brookshire's death. Be happy to look up with more info.
The information stamped on the back of cam, #5 cam bearing jounal
37947 274/284 370.571 thanks. Joe |
UltraDyne Master List
http://www.bulletcams.com/Masters/ultradynemasters.html And if interested the Pontiac page from a old UltraDyne catalog: http://web.archive.org/web/200303250..._camshafts.htm (see HOME on the link for more info ) .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 01-27-2019 at 12:30 AM. |
thanks steve, what I have must be a custom grind with the 274/282 adv. dur because it isn't listed on the master list nor the old UltraDyne list
I couldn't find anything for the # 370.571 or the #37947 so I may not use this came not knowing the specs. Thank you for the information you sent. Joe |
I suppose someone could get that cam, and with a Degree wheel and dial indicator, then you would have the all the spec.
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
![]() Quote:
http://web.archive.org/web/200301140.../hydraulic.htm Subtract base circle OD from base/lobe measurement to see if lift matches up. Like Ted said to get lobe sep and verify what's what. Clay
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
Thanks for the info...I think that is just what I needed.
Hard to beat a good UD cam!
Just an assumption based on what everyone posted but to me the camshaft looks like a "optimized" Harold B RA-IV Hydraulic Camshaft.
Tom v.
In the link I posted above within the Pontiac section....
"Need a replacement for your worn-out RamAir IV cam? This one makes more power. Can use 1.65s for .515 valve lift." 282/290-114 .
The 288/296 has 231/239 @ 0.050 like the RAIV and performs pretty darned good also.
Regarding a "RAIV" substitute with the two UltraDyne hyd flat tappet cams mentioned here and noted below should bring out some interesting comments and emotions
![]() 282/290 114 LSA .468/.468 233/241 288/296 110 LSA . 485/.507 231/239 .
Did you ever uses this cam before?
Do you know if it is hydraulic or solid lifter? Flat tappet or roller? If the 274/284 is duration then is it seat-to-seat or 0.050" R63 310 274 R64 320 284 Stan
Stan it is a hydraulic cam. a friend ran it in a 69 400 4 speed gto. I was thinking it may also be a good cam to use in my 70 gto 455 with casting number 96 d port heads with
headers, modified turbo 350 transmission and 355 rear end. It should be pump gas engine. |
Duration is 274/282
Is that the advertised or 0.050 duration?
advertised 274/282 and 226/233 0.050
