My stroked engine has broke.
So I was out cruising on the week-end with a club when we hit a long straight and I put the foot down and she pulled hard all the way to 120mph, no sign of any problem until I pulled up and was told it started blowing heaps of smoke out the pipes from when I went WOT, and it was still smoking all the way home.
I have had problems with excessive crank case pressure, but when I lifted the hood there was oil everywhere from my breathers, never been this bad before. Anyway I did a compression check and found no compression in number 5! and only 175 in #6 and #7, the rest were 200-210 This is a recent 488 build with top shelf everything, and only around 3000miles on it. Car starts and runs fine except for the smoke machine out back. Whats my next step to determine the cause?
Your car must be very fast ! Because you were haulin ass when I passed you in my GTO. |
Do you notice any strange noises in top or bottom end? I would probably start with pulling the valve covers if you haven't already. Check for anything obvious with valvetrain/seals etc. If you have a borescope tool, check the cylinders through the spark plug hole. Next would be digging deeper with pulling the heads etc.
If you were running pump gas, I would suspect busted pistons.
Your cranking compression is / was high so I would suspect damage from knocking due to timing and or full throttle jetting.
It could a number of things but first off the top of my head would be that you now have broken rings due to lack of proper ting gap on one or both of the compression rings . If the motor was built with hyperutic Pistons and the motor was knocking under full throttle then you could have a broken piston Also note that if you have the broken ring syndrome that the ring are very likely scratching up the cylinder walls so you really do not want to run it any longer. Anyway you look at it your resigned to pulling it out now to find out what's wrong and repair it
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 01-21-2019 at 09:10 AM. |
How hot did the motor run? Time to pop the heads and see what damage you have. You would be lucky if was just head gasket...is your coolant low?
Carburetor building & modification services Servicing the Pontiac community over 25 years |
I'd pull the valve cover off and look at the vavle train for 5 & 7
Rotate engine by hand if nothing major sticks out on looking it over. See if the valves move normally. But with one completely dead cyl. not looking good without taking head off to see further what the problem is.
That's fairly high cylinder pressure for even 94-95 octane. If forged pistons they may have survived. More than likely rings. |
If it has KB Hypereutectic pistons in it, I suspect one broke.
Stick a bore scope in cylinder # 5 and see what's up.
Can't believe your running that high of compression on pump gas a disaster waiting to happen
Tim Corcoran |
Link to Engine Thread
http://forums.maxperformanceinc.com/...d.php?t=817113
400 XX Block, bored to 4.180’’.aligned and decked .0005’’ clearance Fully Balanced and blueprinted 4 Bolt Mains Canton road race oil pan Cloyes billet timing set Tomahawk push rod cover 4.5’’ Forged Eagle Crank 6.8’’ Forged I Beam Rods D.S.S Premium Forged Pistons 6150X Sandoval Stage 4 roller cam 246/252@.050’’ .400’’ lobe lift on a 112 LSA Kauffman D-Port 310cm Alum heads Comp Cams Roller lifters Crower SS rockers 1.5.1 ratio Ported Performer RPM Intake SMI Quadzilla Q-jet 900CFM 10.9:1 CR, Had ping/det problems with first carb running lean. Clay |
ZERO compression? You just spent a lot of money.
"I" would do a leakdown test of (at least) the cylinders with low compression pressures. AFTER the leakdown test, I expect the engine comes out-and-apart for repair. (But sometimes a person gets lucky--which is why I'd do the leakdown test which will confirm whether the problem is piston/rings, or valves (or both). |
Valve covers off back off rockers look for obvious valve stuck open sometimes those heads drop seats. All valves look good move next to removing plugs air up Problem cylinder see where the air goes.
The cranking compression seems awfully high for the stated CR and cam...???
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
I was looking at that Will, but no mention of where the cam was installed. I'll assume with that high cranking compression he's close to sea level too.
The .050 duration doesn't seem all that big for 488 cubes. It would suck up another 10 degrees and still be streetable. 10.9 compression with an aluminum head is easily doable on pump gas...with the right camshaft. |
I burned a TRW forged piston doing the same thing. Probably going more than 120 but it caused the black death.
1979 Trans Am WS-6 .030 455 zero decked flat pistons 96 heads with SS valves 041 cam with Rhoads lifters 1.65 rockers RPM rods 800 Cliffs Q Jet on Holley Street Dominator ST-10 4 speed (3.42 first) w 2.73 rear gear __________________________________________________ _______________________________ 469th TFS Korat Thailand 1968-69 F-4E Muzzle 2 |
Agree, pull the valve covers. A broken intake rocker arm stud on 5 could do that although it wouldn't explain the lower compression #'s on the other cylinders.
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
Ozzmann
Get your paper work back out and double check those cam specs.
Sandoval site doesn't show a cam with the info you posted in the other thread. http://sandovalperformance.wix.com/e...-velocity-cams Duration and lift you did post looks more like their Stage 5 cam that has 108° lobe seperation. That could help explain the high cranking compression and det/ping problem. Clay
All the federales say,they could've had him any day They only let him slip away, out of kindness...I suppose Poncho & Lefty |
For Airfare to Australia, I would be very happy to take a look
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
Engine was very street able, idles nicely and never was a pig to drive, haven't looked at the coolant level as yet, however I did just notice last week that I had a small leak under pressure at the neck, but I did top up the coolant that morning before I left. Wouldn't the oil be milky if it was just a head gasket? Quote:
A lot of you are saying the 200-210 was too high compression, where would you expect it to be? I'm by no means an engine mechanic, have no problems doing bolt on jobs, so pulling this apart will be a first for me, so expect me on here asking plenty of questions men, I will pull the valve cover tonight and see if anything is visible. I will also do a leak down test.
