Old 01-09-2019, 06:42 PM
Default Pontiac oil tech 1931
Thought I'd share a picture of the inside of a Pontiac 6 cylinder circa 1931...
Noteworthy approach to oiling.
First off the oil pump is submerged in the bottom of the pan. Oil gets plumbed to filter mains and cam.
The pan is baffled around the pump and a windage tray is part of the pan baffling.
Not many vehicles this vintage had this level of tech. As late as the 50's some were still dip n splash(Chev 6)!!!
Friday I'll try to post the oil lines that feed the main bearings.
They did a nice job on windage, drain back, and slosh.
ID:	502429   Click image for larger version
The Following User Says Thank You to BruceWilkie For This Useful Post:
Old 01-10-2019, 02:15 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
The pan is pretty shallow. Was the block a skirted design?
Old 01-10-2019, 07:16 AM
Block is skirted. Only 3 mains though. Pan is approximately 5 " deep and dipstick is marked 3,4,5, and 6 quarts. These motors are rather long. It also uses 2 cylinder heads. I suspect for durability.
I'll have more Friday. (VA day today☺️)
Old 04-19-2024, 08:00 AM
Zener424 Zener424 is offline
Default Photo 0f screens & oil pump gasket
For those of you that are interested, here are some shots of the pan with the original screens installed. They seem to have been tack welded to the pan. I didn't want to fuss with having to replace mine, so I did the best I could cleaning them. I've also include a photo of the oil pump felt gasket for reference.
Name:	Pan clean.jpg
ID:	632317   Click image for larger version
Name:	Pump gasket.jpg
The Following 2 Users Say Thank You to Zener424 For This Useful Post:
