Old 01-09-2019, 07:59 AM
tempest1964's Avatar
Default Fuel Neck Bracket
Does anyone make this item? Somewhere between body shops, it has come up missing.. Maybe someone has a used one?
Thanks in advance,
Name:	FUEL NECK BRACKET.jpg
Old 01-09-2019, 08:36 AM
Andre's Avatar
Andre Andre is offline
I have a spare if you don't find it. email me at arayman@Aol.com
Old 01-09-2019, 09:17 AM
Thanks Andre. I will dig thru all the parts at the body shop and let you know for sure.
Thanks again,
Tony
Old 01-09-2019, 11:40 PM
64speed's Avatar
64speed 64speed is online now
I have mine but it’s a little worse for the wear. Is it absolutely essential. Mine wasn’t even screwed down when I got the car.
Old 01-10-2019, 08:39 AM
remy30006 remy30006 is offline
does anyone happen to know what finish these had? Gold?
Old 01-10-2019, 09:52 AM
I found this on Scott Tiemann's web site. I imagine it is probably correct, knowing his reputation for proper restorations.
Name:	FILLER NECK BRACKET.jpg
Old 01-10-2019, 12:11 PM
johns johns is offline
Don't forget the filler neck grommet-
Old 01-10-2019, 12:30 PM
Yes. Our host ( among others) carries it
Old 01-15-2019, 01:17 AM
Dick Boneske's Avatar
I did mine yellow zinc, but clear zinc
like the Tiemann picture would be OK, too.
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 01-15-2019, 06:47 AM
Thanks Dick. I wasn’t sure what that costing was.
Old 02-07-2019, 08:07 PM
JAKE 64 JAKE 64 is offline
For 1964
I believe all of these Fuel Tank Filler Grommet Retainers (brackets) would have been provided with gold iridite over silver cadmium. While the layer of silver cadmium (not zinc) is typically always present, the ability of the gold iridite coating to survive the elements is not as good. Whenever I have found gold on this bracket, it is normally on the somewhat protected underside.
Sometime during the life of the bracket shown below, and most likely during the initial factory installation, the rubber grommet was pinched and never properly seated. This rolled portion of the grommet formed a tight bond, protecting the gold iridite from the elements.
Photo 1 shows the fine line of gold surviving under the protected area (5:00). Photo 2 shows the reverse side that benefited from this same protection (12:00).
All three photos show the general condition of this bracket, removed from a car with 30 K+ miles. As can be seen, the cadmium coating remains prominent over most of the bracket, but not so for the iridite, even with the low mileage noted.
This bracket is the only one that I have ever noted to have the gold iridite surviving on the top side (thanks to the pinched grommet). Typically if the iridite even survives, it is found on the reverse side.
Name:	1964 Fuel Grommet Retainer 001.jpg
ID:	504988   Click image for larger version
Name:	1964 Fuel Grommet Retainer 002.jpg
ID:	504989   Click image for larger version
Name:	1964 Fuel Grommet Retainer 004.jpg
Old 02-07-2019, 08:21 PM
Jake, thanks for the in depth reply. Much appreciated.
Old 02-07-2019, 08:27 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Extremely low mile 64.
ID:	504992   Click image for larger version
