Dyno Day 461 Stroker
Back in Sept I was looking for an engine builder for my hurt 66' Goat engine. It is a 1970 400 that had been rebuilt by the previous owner. I purchased the restored car with 1100 miles since resto. At about 2650 miles, after a hard run through the gears she started knocking and oil psi dropped...
I came here for advice on builders and one of the members recommended Mr. Wayne Sless out of Greenwood SC. I had quotes from Butler, Kahffman, DCI, Tin Indian and a couple more smaller shops. I called Mr. Sless and we hit it off. He's a GREAT guy to talk and deal with as well as being a master machinist and builder. The decision was made and I hauled the engine 300 miles to Wayne. We talked for over an hour, he listened to all my wants and needs (even though he knew more about what I wanted than I did). He tore the old engine down, diagnosed the trouble, did all of the machine work and went to work on the build, a 461 stroker. he used Eagle 4340 crank and eagle rods, SRP pistons and a custom ground Erson cam. He used my block, Edelbrock heads and intake and my 750 DB Holley carb. On Saturday dec 29th we did the Break in/Dyno/Tune at Mr. Bob Szabo's shop. Bob completely reworked the carb. Here is the Dyno day video with results!! https://youtu.be/0D6CYb3oTNI |
Very nice !
568 tq at 4200 rpm 559 hp at 5600 rpm Nice 1400 rpm spread between peak tq rpm and peak power rpm.... probably a roller cam ? What are the specific specs on the cam ? Flow numbers on the heads ? Compression? Intake ? Etc. .
The compression is 10.4 : 1 , the intake is an Edelbrock Performer RPM Tommy |
559 HP FROM A 461 STROKER WITH A 750 CARB IS A REALLY NICE NUMBER.
Congratulations. You have a good team there and the engine will be a lot of fun to drive. Old school dyno but I like those the best. Very nice dyno cell set-up. Tom V.
Tommy |
Dyno day's are fun when it all goes smoothly!
Nice job congrats!
Carburetor building & modification services Servicing the Pontiac community over 25 years |
My apology to the OP for posting the cam specs and to the engine builder that for some odd reason did not want them divulged. The hydraulic roller lobes are listed on the Erson website and were previously posted by the OP within another thread for everyone to see. Cam specs are very pertinent when evaluating a engine combination but they have now been removed here.
http://www.pbm-erson.com/UserFiles/D...MASTERS_15.pdf ONWARD THRU THE FOG .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 12-31-2018 at 03:43 PM. |
Nice job and congrats on the numbers it sounds like a fun day..Dyno day can be hectic
Jim Moshier 1971 Grand Prix 462ci SD Performance 6x heads 1962 Catalina 389 1968 Firebird 400-455 I haven't decided "If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan |
Great video and that’s going to be a brute street engine. Nice when all the planning and work comes together.
I had the same thrill last spring . No questions on what the engine puts out...congrats |
After the 3rd pull Wayne told me that we were just an intake manifold and a few tweaks away from 600/600...
Tommy |
The TQ/HP curve from pull #1. I didn't snap the other 2... TQ Blue, numbers on left, HP Yellow, numbers right. Pretty darn flat...
Santa left you some horses indeed!
Fantastic numbers.
Be interesting to try a larger carb. What head flow? Last edited by ponjohn; 12-31-2018 at 11:26 PM. |
Ver y nice. It will be an excellent street engine.
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
Wayne is my machinist and engine builder
My experience with Wayne has been exceptional, start to finish. He exceeded my expectations on all fronts.
Thanks for the referral . Now to get the goat back on the road!! Tommy |
I'll have to check with Wayne on the head flow. According to Bob Szabo, aka "Carburetor Bob", the worked over 750 dp is providing all this engine needs...
2) Trust Mr Szabo and his comment about the carb and see if the engine (AND YOU) are happy with the overall drive-ability of the engine/vehicle package. Don't change parts just to put a slightly bigger number on the board. 3) An example: Mr William Klausing at one time raced a 1963 Wagon at 4100 pounds scale weight, if i remember correctly. He was a big man and weighed another 300+ pounds so 4400+ pounds going down the track. With proper suspension tuning the car would do a 1.6 60 ft time at that weight. Lots of other cars were doing 1.9 to 2.0+ 60 ft times. The car originally would run 12.60 quarter mile times. With a reduction in weight say 3600 pounds race weight the car would have been much quicker. 4) So Mr Klausing had 3 of the largest 2 BBL Holleys made on a Tri-Power intake. These were rated at 625 cfm each (at a 2 bbl test pressure). A bit over 1000 cfm for 3 carbs (at a 4 BBL test pressure rating). So Bill K had lots of CFM capability and the ability to change cfm easily with how far open he had the outboard carbs at Max Engine RPM. At the end of the carb testing over a couple of seasons of racing, basically leaving the engine alone except for normal maint and playing with the carb cfm needed flow, the car ran 12.06 quarter mile times. This was with the carbs dialed back to the "IDEAL" cfm for best overall power racing down the quarter mile strip. (The end carbs were never opened completely), so his engine did not need that extra cfm to run its best times and best mph. They were probably about the cfm ratings of a triple set-up of "500 cfm" carbs or the rating of the typical 440 six pack #4782 center carb and #4783 outboard carbs that Mopar specified for the drag race Mopar Engines. Holley and Chrysler sized their carbs to a specific size for a reason. So TRUST Mr Szabo and run the 750 carb you have for a year. Then Borrow a 850 CFM carb and do a back to back test on the track on the same day. You might be surprised with the results. Tom V. There are some GOOD Carb Guys out there. Shaker455, Cliff Ruggles, Jon Hargrove, Roger at C&S Carbs. There were some really good Holley Guys at one time: Chuck Gulledge, John Reed, and Mr Braswell(Sr) to mention three. Mr Braswell(Sr) passed a lot of carb knowledge on to his son David Braswell (Braswell carbs). Mr Braswell(Sr) was a Pontiac Racer. (If you want restored Rochester Tri-Power carbs, we have a couple of experts like Dick B and Mike W to help those people)
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 01-01-2019 at 09:33 AM. |
Awesome Caster! Gotta love it when a plan comes together and those numbers are even more impressive w a 750. Apparently Wayne and Bob know what they're doing. I'm very interested to hear how it does in the car, hopefully some track results also.
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
Great build! The video is great! Nothing better than having your engine builder and a carb guru dyno your engine.
What intake ?
