Anybody use these? BMR AA033H.
71 Lemans Sport. 72 Lemans Sport. |
BMR makes good products. Call them and get the Delrin Bushing option instead of the Urethane.
I used Smith Racecraft nice stuff
Smith makes nice products, unfortunately they don't make them for the Chevelle/GTO chassis.
Well you learn something everyday …
If you are going the upper and lower route and use a TRZ or similar set up be aware that using them will lower your ride height about 2" if you keep the same springs. Also the aftermarket replacement shocks like Afco's, Qa1's etc will be too short. And a drop in coil over system like the Qa1 will lower the front end a lot.
Found out the hard way with my Cutlass. It turned into a major pain in the ass. There aren't a lot of early A body spring choices which complicated things. It still doesn't sit where I want it but it works so I left it alone. Do your research.
1992 Pontiac Formula race car 1965 Olds Cutlass race/street car 2016 SRT 392 Charger 1 of 113 |
![]() Quote:
![]() Quote:
11.940@114.21 / 1.843 60'/ 3980 lbs 1964 corvette roadster 1968 corvette roadster 1962 corvette "equal rights, not equal things" if you want to know the future, read "atlas shrugged" I dont race a 4spd because it is easy, I race a 4spd because it is hard. ![]() |
TRZ!
