Launch retard w/Power Grid /Nitrous
Got my new power grid was setting up the launch retard new trans th400 210 w/a brake leaving on the bottle .Neal Chance converter 4000
Base timing 32 |
Really nobody in here has any experience setting up a msd power grid to leave on T-brake on nitrous.. . Ok no problem ..
It depends on a few things.
Is it 1 kit or 2? if its just one is it on a progressive? (If so need to know what the ramp is on that.) How big of shot are you spraying? How much timing are you pulling for the nitrous? And MOST of all how good the track is and how much the Chassis / Track can take from the launch. But here is generic launch retard Grid
6.98 @ 199mph 4.53 @ 164mph |
Ok One Kit fogger No progressive Shot Size for now is 275 Base timing 32 pulling 8 Track is always good car has been 1.24 60ft on a small plate 150 shot Last edited by Mark G; 11-21-2018 at 12:22 PM. |
Mark there is no real chart to go by here. It all about what you're combo likes and can take. I'm not a nitrous guy and I'm sure there are several on here that could speak with more knowledge about it ( Lil Jack / Kinsler ). But I would probably start pretty close with the 4 degrees over .75 like above and adjust it from there. If it spins pull more or stretch it out longer. It if doesn't spin pull less until it does and back up one step. Just my opinion (which don't mean chit ) Good luck
Mark, what specifically are you trying to do?
Going from a 2.48 to a 2.10 first gear will calm the leave down. Honestly with a 275 shot and a good track you might not need to pull any timing. The fastest it will gonis by getting all the Nitrous and timing it will take as fast as possible.
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
540 c.i. Ultra Street Combo Tiger Heads with Tiger Intake Induction Solutions fogger with .046 jet First ultra street/ultimate street NOS car to get into the 4's! 1.079 4.559 153.23. 3100 lbs 7.77 @ 169 1/4 Mile (2015) with EHTTFMF!! T2TTFMF! Special Thanks to: Ron at Rhodes Custom Auto Butler Peformance Jim Hostler's Transmissions (HOSGTO) on here Induction Solutions BES Racing Engines. Cheeseburger VP Racing Fuels Calvert Racing |
Lol not sure yet new transmission from Hutch never had a brake before this trans has a 210 first gear converter is a 4000 I was thinking leaving at 3500 but I sure could use some advice on this .My car works pretty good foot braking 1.24 60ft my track is always good .. Thanks Jeff
GTO George |
Thank you George was looking for racer with experience programming a Msd power grid box on nitrous leaving on a t-brake.Could you share your experience with us because I have none so I ask other who do … That is just common sense...
Same goes with a tire pressure gauge and a degree wheel.
X2.
You’re funny!
GTO George |
Thanks Jeff just try to figure out the grid and how to pull or put timing in then how much to start with.. ..
GTO George |
Thanks George I have been reading on Yellow bullet.. I will learn it guaranteed
Why go to you tube? Jeff and Jack seem to have it figured out... I would go with their advice.
