Old 11-11-2018, 06:07 PM
Beige1968GTO Beige1968GTO is offline
Default Straightening bent “C” section of Frame
So back before I knew any better, when I first got my GTO some 30 years ago I jacked it up on the “C” section on the side of the frame and bent it upwards.
Any suggestions as to what tool can I use to bend this back into place?
Ron
Old 11-11-2018, 06:18 PM
Sirrotica's Avatar
Sirrotica Sirrotica is online now
A large cresent wrench or a pipe wrench.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 11-11-2018, 06:34 PM
PurelyGTO68 PurelyGTO68 is offline
You can try two pieces of flat bar stock (3/8" or thicker) and some C clamps. I have straightened many channel flanges using those tools.
Sent from my SM-G930V using Tapatalk
Old 11-11-2018, 07:11 PM
melemans's Avatar
melemans melemans is offline
I used a piece of 1/2" flat steel clamped over the bent section(s) and then I used a large crescent wrench and a large pipe wrench to bend the frame back in position. Slid the flat steel up and down until the bends were all
worked out.
Old 11-11-2018, 07:38 PM
Default Thank you
That is great advice! Thank you.
Ron
